Does the 335d run on Bio-diesel?
01-12-2010, 02:47 PM | #1 |
60
Rep 910
There is a service station near my home that sells bio-diesel and was wondering if the BMW diesel engines run on it. I understand that the bio-diesel is not to be used in the winter, but can be used without any problem 3 out of the 4 seasons here in New England in most modern diesel autos.
Can the 335d or the X5d run on bio-diesel? |
01-12-2010, 02:59 PM | #2 | |
16
Rep 231
01-12-2010, 08:11 PM | #4 | |
13
Rep 171
Looked at gas cap today.
2012 SG 740i
01-13-2010, 07:05 AM | #5 |
3572
Rep 10,352
IIRC the manual says B7, but nobody sells B7. I've thought about it myself, but there isn't a station within a reasonable distance (Atlanta) to make it worth my time.
01-13-2010, 08:47 AM | #6 |
21
Rep 436
The owner's manual says B5. If you read up on bio diesel you will fined that there are many good reasons to use it, if you can get B5 in your area I would use it, your car may be better off for it...If anyone is interested I will list some the value of using B5 in your engine.
HS |
01-13-2010, 09:04 AM | #7 | |
3572
Rep 10,352
* US Diesel is made with a slightly higher scar wear rating than Euro diesel. |
06-24-2010, 10:40 PM | #8 |
Rep 8
Well.. my car just hit about 1000 miles.
I have been using B2 since and just today I switched to B100. The only things ive heard is at first if your car has been using petrodiesel for a long time the bio diesel will clean everything and cause ur filter to go faster at first.. According to everywhere Ive checked pretty much any diesel engine is capable of running biodiesel. There have only been issues with older engines because the biodiesel ate away some specific tubing.. but those have since been eliminated in any engine produced recently.. |
06-24-2010, 10:44 PM | #9 |
138
Rep 1,424
Drives: '23 i4 M50, '15 M3, '18 911
You can run biodiesel, but it will contaminate the oil more quickly. That's one of the main concerns on the current VW diesels. If you run higher than B5 then you better change the oil much more frequently. Also note than bio could mess with the emissions system as well.
06-24-2010, 10:47 PM | #10 |
Rep 8
so change the oil more frequently.. i love doing that. Love to have my car feeling clean inside lol. The emissions system is gonna squirt that nox negative stuff in regardless right?
06-25-2010, 06:55 AM | #11 | |
3572
Rep 10,352
The B100 will very likely turn into gum within your injectors due to the extremely high pressures and it will kill your DPF and oil. Word is B100 turns motor oil useless (dilution) in about 2000 miles in the 2009+ VW TDI's. Save the bio for the late model VW/MB whose injectors run at much lower PSI. Last edited by F32Fleet; 06-25-2010 at 01:22 PM.. |
06-25-2010, 10:46 AM | #12 |
21
Rep 436
The statements about the VW are true for the newer models and Bio. The interesting thing is why. I hope I can explain why they have trouble with bio. VW doesn't use the AgBlue system that BMW and MB use. The way they get the system to meet EPA standards if different. What they do is after the combustion of the diesel on the power stroke the injector squirts some fuel into the cylinder as the exhaust leaves the cylinder and is burned in the exhaust to reduce NOx. This causes a problem for injectors that the BMW doesn't experience because the BMW doesn't do that, the AgBlue does the job and very well I might add, it's clean very clean. It has nothing to do with high pressures.
HS |
06-30-2010, 03:42 PM | #15 | |
3572
Rep 10,352
Like I said. Leave the B100 for the late model VW/MB. If you're worried about lubricity then B2 is all you need. Anything more and you get no improvement. Now move along cause I'm thinking.... |
06-30-2010, 04:21 PM | #16 |
92
Rep 348
08-27-2010, 07:03 AM | #20 |
3572
Rep 10,352
08-27-2010, 08:23 AM | #21 |
73
Rep 1,770
so i know i could google this and figure it out but what exactly are the benefits of bio diesel and the differences between the ratings.
i should google to educate and i probably will but just so u guys can tell me w/ your experience. |
08-27-2010, 08:31 AM | #22 |
Throbbing Member
43
Rep 1,433
You pretty much have to stick with an old diesel if you want to run "alternate" diesel fuels.
There are plenty of guys running old Mercedes diesels that are converted to run on used frying oil. They basically get their fuel for free if they know fast food restaurant owners and the exhaust smells like french fries. Owners of new "clean diesel" engines will never know the pleasure of french fry exhaust.
2014 Tesla Model S 85kwh
Previous cars: 2011 335d / Deep Sea Blue / Saddle brown / sport / premium 2008 BMW 135i / 6MT 2002 Z06 Corvette |
