Problem with gear shift
I'm driving a '08 335i coupe, automatic. The other day I was driving in sport mode and then suddenly when I was accelerating (I wasn't manually shifting) it felt like the gear was 'in between gears' and the exhaust was making a deep pitched rumbling noise and the car was shaking a bit. When I pressed on the gas it would aggravate the symptoms and actually the car wasn't accelerating that much even though I was pressing on the gas pedal. So I had to pull over, turn the engine off, and when I restarted it everything was fine. Has this happened to anyone and if so, what is the problem and solution? Thanks in advance.
