Coats of Paint
01-05-2010, 01:26 PM | #1 |
167
Rep 2,210
Coats of Paint
Getting a bumper painted - how many coats of paint should I expect? This painter is telling me a base coat and a clear coat. Is that enough?
Any other questions I should be asking to find 'the right painter'? |
01-05-2010, 06:02 PM | #3 |
Once upon a time ......
276
Rep 5,048
Drives: 2008 JB E92 - SOLD 5/2010
Depends on how good the shop is.
Average coats would be: Single coat of filler primer (or 2 coats of primer if not using filler) 3 coats of base color 3 - 4 coats of clear coat High end shops will add 2 coats of everything including the primer as filler is sprayed, sanded and primered again. (Very general idea given, but basic) |
01-05-2010, 06:07 PM | #4 |
276
Rep 5,048
I would ask him what process he uses ........ product line (DuPont, PPG .. PPG would be the best match to the OEM grade of paint).
Is he going to use a filler primer? (It's expensive, but definitely leads to a quality finish and tends to be a much more durable bond/base for the color) Will the finish be wet sanded & buffed to match the clarity to the rest of the car? Or will it just be buffed? (you want the finish to be wet sanded AND buffed. Wet sanding will ensure the finish is 99% perfect with regard to particles embedded in the clear) If you're going to another independant shop then it's always a good thing to see any other work they've recently done. Although this would be better based upon your car receiving a total repaint. |
01-05-2010, 09:12 PM | #5 |
167
Rep 2,210
Appreciate the response Toad The guy I'm most likely going to go with has a good reputation but is hard to get information out of sometimes.
His response on method was that he uses PPG, 3 good coats of clear - color sanding and buffing is also included. So I guess the only question at this point is how many coats of primer/filler and how many coats of base he will be using. |
01-06-2010, 07:50 AM | #6 | |
276
Rep 5,048
Now, most paint is water based which lends to some flexibility. Something else to watch out for is the fact that if a car's painted plastic/poly bumper is hit with enough force; damage is likely to appear at some point down the road in the form of hairline cracks within the base coat ....... beneath the clear coat. |
01-06-2010, 07:56 AM | #7 | |
276
Rep 5,048
Filler primer is also known as the "yellow" primer. If the bumper is being repainted then he may use it. If the bumper is brand new & receiving it's first coat of paint then there isn't much need for it. Good shops use it for its durability & overall quality while average shops may use it to cover up mediocre work (filling in sanding marks rather than sanding them smooth). |
