Anyone have a 335i DMS Remap or BMW Performance brakes?
01-04-2010, 11:10 AM | #1 |
19
Rep 236
If you have the DMS 335i remap how do you find it? Customer service/backup good?
Also, anyone using the 6 pot brake upgrade? Looks very cheap for a complete kit! Who makes the calipers? Can't be that much more expensive than new discs/pads. |
01-04-2010, 01:37 PM | #5 | |
Moderator
324
Rep 5,493
Yes. and Yes ! This is a good link too.. http://www.e90post.com/forums/showthread.php?t=257531
... ... DMS Remap Review ----- Quaife LSD Review ----- Hartge Antiroll Bars Review ----- Bilstein PSS10 B16 Ride Control Review ----- Detail by ShineOn ----- Paintshield Review |
01-04-2010, 03:37 PM | #6 |
Zummerzet Zyder Drinker!
112
Rep 5,541
Drives: '06 330D Le Mans Blue
Made by Brembo.
I have a set on my 330d. Looks the nuts.
01-04-2010, 04:05 PM | #7 | |
263
Rep 2,562
Alpina_B3_Lux
Audi R8 LMX, BMW M550i xDrive (G30 LCI); gone: Alpina B3 3,3 (E46), BMW 335i, Audi R8 V10 manual, Audi R8 V10, BMW M235i, BMW 550i F10
01-04-2010, 04:05 PM | #8 |
19
Rep 181
I've been searching most of the evening about the BMW Performance Brakes and after several beers later, these brakes are:
1. not suitable for a 335d 2. Are ok on the 335d 3. not made for the 335d 4. Made for 1 series 5. The stock brakes on a 335d are better 6. BMW Performance Brakes are better than the stock brakes 7. I should spend 5-6k on a set 8. I should leave the originals on and forget about it 9. I should buy a faster car In front of me i have a BMW performance catologue and it clearly shows these brakes are available for the 3 series yet in small print it says 'Product availabilty dependent on vehicle specification'. Can someone confirm or just make me more confused if these BMW Performance Brakes are suitable for a 335d as i can't wait for the dealer to open tom For me they are more for 'show' rather than charging around a track so would rather not spend £1000's on a set of 4 to be total overkill. Also, despite the nice shiny yellow caliper, would the disc size look a little crappy on 19" 269 wheels compared to stock disc size? A lot of the posts i've searched on are from 2008/early 2009 so have BMW come up with any upgraded brakes for a 335 in this time? |
01-04-2010, 04:11 PM | #9 |
19
Rep 181
01-04-2010, 04:25 PM | #10 | |
Moderator
324
Rep 5,493
The bottom line is this - 1) The BMW Performance BBK can fit any of the 1er or 3er cars, except the M3 2) Although it can fit the 335i and 335d, BMW have not designed the BBK to be used on those two models, because it is more of a sideways step in braking performance than an increase in braking performance. On all other models up to and including the 330d and 330i pre-LCI, the BMW BBK can be used as sanctioned by BMW. On 330d and 330i LCI cars (ie. '09 model onwards) these have been upgraded to use the stock 335i/d style brakes, and therefore the BMW BBK is not sanctioned by BMW to be used on these LCI 330 models 3) BMW will NOT be producing a brake upgrade kit for the 335i or 335d, nor for the LCI 330i or 330d, as BMW have deemed those particular braking setups to be more than adequate for the power those cars produce.
01-04-2010, 05:49 PM | #11 |
112
Rep 5,541
Very well put Tony.
The 335D brake discs are bigger and thicker than the BBK disc. I did, somewhere, have all the disc sizes and thicknesses as I was in a similar position recently when I was researching the BBK for my 330d. I'm just not looking forward to replacing the brake pads when the time arises - only available from BMW at £200!
01-04-2010, 05:58 PM | #12 | |
19
Rep 181
I saw you recommended AP Racing brakes in another thread which look nice. I'm guessing fitting these is a this a job for a more specialised company and won't be local to me? |
01-04-2010, 06:31 PM | #13 | ||
Moderator
324
Rep 5,493
I think the fronts are around the £1900 + VAT mark, so expensive when compared to the BMW BBK, but lightyears better in terms of performance and durability. I wrote the following when answering another member's question about BBK kits in general, and why the BMW BBK is so cheap in comparison to the more established products... Quote:
