Studio RSR
BMW 3-Series (E90 E92) Forum > BMW E90/E92/E93 3-series General Forums > Regional Forums > UK > UK Off-Topic Discussions > Putting hot water through pressure washer
      01-03-2010, 03:48 PM   #1
E90Yaz
Torque Monster
England
17
Drives: Porsche 911 Turbo
Hi guys, I tried this in my baby Karcher for the first time in the 4yrs i've owned it the other day. And it became quite lethargic and didnt like it. Has anyone tried this before? Are pressure washers not designed to use hot water??
      01-03-2010, 03:58 PM   #2
M3-FAST
Defected to the dark side.....
M3-FAST's Avatar
England
210
Drives: BMW M5 LCi
I think some are but it says in the spec if they can or can't - you will also pay £600+ for one!
The prob normally lies with the water pressure. Pressure washers need quite a high water pressure and a lot of hot water comes from immersion tanks, etc at lower pressure, hence why yours might have felt lethergic. With a modern pressurised hot water system it 'may' work better?
      01-03-2010, 04:02 PM   #3
Mid_West
17
Drives: 335i
My Karcher specifically says not to use hot water. The ones that 'produce' hot water usually have a heater built in them that does the heating and yes, they are expensive.
      01-03-2010, 04:29 PM   #4
I335
I335's Avatar
123
Drives: '08 335i Coupe
I could be mistaken, but the water running through that machine also plays a role in keeping the pump cool. Running hot water through it will overheat the motor and seriously decrease its lifespan. I'm really guessing here as I'm not absolutely positive but it makes sense. Whoever knows for sure - feel free to correct me.
      01-03-2010, 05:23 PM   #5
NFS
NFS's Avatar
275
Drives: M340i
I thing they actually positively pump water through the system. So if you are using cold, then the water flow rate to your property is actually increased while the pump is running. Pumping against the hot water system is going to cause problems IMO.
      01-03-2010, 08:35 PM   #6
E90Yaz
Torque Monster
England
17
Thanks for all your info guys...I will try and find one that can accept hot water in future!
      01-04-2010, 03:12 AM   #7
Dr Dave
Zummerzet Zyder Drinker!
112
Drives: '06 330D Le Mans Blue
My Stihl cold water washer says NOT to run hot water through it.
A machine to provide hot water will be big and expensive!
      01-04-2010, 04:23 AM   #8
dxb335d
The Tarmac Terrorist
dxb335d's Avatar
England
949
Drives: 997.2 GT3
I rekon you have facked it mate
997.2 GT3
      01-04-2010, 09:06 AM   #9
E90Yaz
Torque Monster
England
17
NAh its still working fine....Its GERMAN afterall
      01-05-2010, 02:28 PM   #10
badwolf340
badwolf340's Avatar
Drives: M4
Better off getting HOT pressure washer .I have a King 120 Hot washer,£499 Ex vat,Machine mart do vat free day's.good unit ,use my Karcher fitting's with it ,snow foam gun etc.110 bar pump pressure,cold or up to 70 degree C.
water flow rate 6L/min.4 Ltr fuel tank,1.8 Ltr fuel consumption.
harmon kardon ,performance steering wheel,rear spoiler,black grills ,viz pack,heated seats ,sun protection
