SOLD: New BMW Bentley E9X service manual
12-17-2009, 12:20 AM | #1 |
Rep 68
SOLD : New BMW 3 Series (E90, E91, E92, E93) Service Manual: 2006-2009 MSRP=$129.95 Asking $50.00 Contains in-depth maintenance, service and repair information for the BMW 3 Series from 2006 to 2009. The aim throughout has been simplicity and clarity, with practical explanations, step-by-step procedures and accurate specifications. Whether you're a professional or a do-it-yourself BMW owner, this manual helps you understand, care for and repair your BMW. The do-it-yourself BMW owner will find this manual indispensable as a source of detailed maintenance and repair information. Even if you have no intention of working on your vehicle, you will find that reading and owning this manual makes it possible to discuss repairs more intelligently with a professional technician. Normally aspirated models (6-cylinder 3.0 engines) 325i, 330i, N52 engine (rear-wheel drive) 328i, N52KP, N51 engine (rear-wheel drive) 325xi, 330xi N52 engine (all-wheel drive or xDrive) 328xi N52KP, N51 engine (all-wheel drive or xDrive) Twin turbo-charged models (6-cylinder 3.0 engines) 335i N54 engine (rear-wheel drive) 335xi N54 engine (all-wheel drive or xDrive) Transmissions covered (remove, install, external service) Getrag GS6-17BG manual ZF GS6-37BZ(X) manual ZF GS6-53DZ(X) manual GM GA6L45R automatic ZF GA6HP19Z automatic Technical features: Maintenance procedures from changing the ATF to replacing the cabin microfilter. This manual tells you what to do and how and when to do it. Step-by-step variable camshaft timing (VANOS) service for N51, N52 and N54 engines. Cylinder head cover gasket and crankshaft seal replacement. Cooling system and radiator service. Fuel injection and ignition system diagrams and explanations. Information about advanced technical features such as Valvetronic, xDrive, twin turbo boost and DSC (dynamic stability control). Suspension repair procedures. Brakes, steering and ABS troubleshooting and repair. Heating and air-conditioning repair, including A/C component replacement. Body and hood repairs and adjustments. Electrical system service, with an easy-to-use illustrated component locator section. Comprehensive wiring schematics, including fuses and grounds. BMW OBD II diagnostic trouble codes, SAE-defined OBD II P-codes, as well as basic scan tool operation. BMW factory tolerances, wear limits, adjustments and tightening torques.
[SIGPIC][/SIGPIC]2008 M3 E93, Alpine White
12-17-2009, 09:06 AM | #3 |
Rep 68
This is a brand new manual that just came out this October. cheapest discounted price I have seen for it is $81.87. It doesn't include the new E93 M3 I just purchased is why I am selling it.
