For the love of gahd, how to you get the H7's out of the BIX housing?!?!
10-11-2006, 11:32 AM | #1 |
50
Rep 1,159
Original thread here but the info is pretty sketchy.
Anybody done this themselves? I yanked the wheel well liner last night and went to town. Everything's easy to get to by the H7 DRL/Flasher bulb. Anybody know how to get that out? I yanked out the blank plastic stick plug, then spent about 30min with needlenose pliers trying to gank it out and it wouldn't budge. Then I spent another hour trying to blinding get the stick plug back on the bulb. So frustrating. If somebody who has actually done this successfully can chime in I'd really appreciate it. Thanks. |
10-11-2006, 06:22 PM | #2 |
50
Rep 1,159
bump for me because I'm going to be in there again tonight.
Does anybody at least have pictures of the back of the BIX housing when they had it out of the car? |
10-13-2006, 11:49 AM | #5 |
Got Seoul?
116
Rep 2,862
Drives: 2012 535i MSport
PM Longtran!
Can you say Alooooha?
[SIGPIC][/SIGPIC] |
10-13-2006, 08:23 PM | #6 |
112
Rep 2,589
Here is a thread on H7 bulb replacement.
H7 bulb replacement Link Lots of people are having the same problem. Last edited by nyc3r; 10-13-2006 at 10:31 PM.. |
10-13-2006, 09:27 PM | #8 |
50
Rep 1,159
Yup, inner high beam/DRL bulb.
Problem is, with the BIX housing, the plug is this long plastic stick and without the entire headlight assembly out we can't see how to get the bulb to release from the socket. Not sure I've got the balls to pull the whole bumper just to pop the headlight assembly off just to get to the high beam/drl bulb. Did you happen to notice how it goes in the socket when you had the headlights off? |
10-14-2006, 01:04 AM | #9 |
304
Rep 1,928
Drives: had e90, 330i mystic blue
I got the bimmian set for my xenon flashers and it has been seating there in the book shell for the last 3 moths I can't get it off !! and they are horrible is the only light is my car that remains yellow, I change the int lights, angel lights etc... I just can't get it out !!!!
E90 Mytic Blue 330i 07-20-2006. 05-17-2011
Doesn't the idea of making nature against the law seem to you a bit . . . unnatural? Support NORML |
10-14-2006, 09:25 AM | #10 | |
79
Rep 876
10-14-2006, 11:51 AM | #11 |
1312
Rep 10,185
You are supposed to press the black stick upwards/downwards ( cant remember which one) slightly and then pull it out with the bulb attached.
Seems like you pulled the black stick out without the bulb Pushing the stick upwards/downwards unclips the bulb Mauybe you can try and stick it back in and get it to clip onto the bulb again
BMW if you are reading, I need a job, Please. |
10-15-2006, 02:03 PM | #14 | |
50
Rep 1,159
Ended up being a lot easier than it seemed like it should be. This,
Secret is, get your finger underneath the stick and pry UP. It'll almost feel/sound like something's breaking (metal on metal grating noise) and it'll pop right out. Getting it back in takes a little bit of patience, but it's the reverse of taking them out. Make sure tab is at the top, put in angle down and click back in. It'll go in with less force than it came out so don't be alarmed when it just pops in. You pretty much *have* to have the wheel liner off to do the driver's side, just to get the cover off. There's enough room to swap bulbs from the top. No pics, couldn't really get any. |
10-17-2006, 11:24 PM | #15 |
304
Rep 1,928
I don't get it I will have to try again tomorrow
10-18-2006, 10:39 AM | #16 |
50
Rep 1,159
Okay, you got the stick plug right? Don't pull on it, don't even squeeze it between your fingers. I couldn't get enough leverage on it by squeezing the end and pulling up on it.
Instead, if you you're looking down at the housing from the front of the car, I put my finger as far up and underneath the stick plug as I could get, and pulled up; prying the stick plug up. It'll make a metal on metal scraping noise and then *ping* it'll pop right out. If you feel the plug slipping on the bulb prongs, stop. You should easily get the bulb to pop out still attached to the plug. It still won't feel like you can pull it out because there's a wire running across the top of the opening that you get snagged on. But look at the bulb from the front of the car and you can see that it's loose now. One thing that surprised me was that the new bulbs went in with a lot less force than the oem bulbs took to get out. I kept thinking that they weren't seated properly. But they're in there and seated fine. Oh, you can easily get this done without removing the fender liner on the passenger side as long as you can get the cover popped off the headlight. On the driver's side, I was able to get the plug un-seated without removing the airbox but I didn't have enough room to pull it out from up top. My hands are too big. But technically, as long as you could figure out how to get the cover off through the access panel you wouldn't have to remove the fender liner entirely. |
10-21-2006, 01:52 AM | #17 |
QuickShifter
137
Rep 1,500
haha...my H7s are still sitting around doing nothing
i'm willing to pay someone to help me do this either some shop or just get BMW to help me do it when i go service.... |
