Need help with offset/spacers needed! Pics included
12-04-2009, 05:02 PM | #1 |
64
Rep 912
Hey guys so im trying to figure out what kind of spacer to run. I am running BBS Lm reps. Here are the specs on the wheels:
19x8.5 fronts and 19x10 rears +35 fronts and +38 rears I am trying to figure out what spacers to use in the rear. I was thinking 15mm spacers but i don't know if that will be too much. I am going to be installing my KW V2's soon and plan on going pretty low and i want to do my best to avoid rolling my fenders. Im also wondering if i should run a spacer on the front or not. Im including pics to show what the wheels currently look like. All comments/advice and help is appreciated. Thanks!
12-04-2009, 05:35 PM | #2 |
379
Rep 11,992
Drives: M3 (e92), X5 (E70), 428i (F32)
5mm spacer in the front and if you have rolled fenders you can run a 5mm in the rear
Anything more than a 5mm in the rear is gonna cause you rubbing if you don't have an aggressive alignment |
12-04-2009, 05:36 PM | #3 |
Midlife Crises Racing Silent but Deadly Class
1821
Rep 5,337
Drives: 2006 MZ4C, 2021 Tesla Model 3
Is this purely for looks, or is it for performance reasons?
For looks, just measure the distance from the vertical surface of the sidewall to the edge of the outside fender. THAT distance plus 2-3mm is the optimal spacer you need to run. Reason being, as you lower the car your negative camber will increase, thereby tucking in the top of the tire as your suspension compress, so you can actually run a couple of millimeters outside the fender and still not rub ON THE STREET. For performance? I wouldn't add spacers. |
12-04-2009, 05:41 PM | #4 |
64
Rep 912
its purely for looks. 5mm? Thats hardly noticeable im wondering if i should even run any at all now. Spacers aren't cheap. I was thinking originally like 12mm spacers.
12-04-2009, 05:42 PM | #5 | |
379
Rep 11,992
As for the rear, if you roll your fenders and those are 265's on your car, you may be able to get away with 8's If you run aggressive camber on top of all that, you can fit a 12mm in the rear. |
12-04-2009, 06:07 PM | #6 | |
64
Rep 912
12-20-2009, 01:18 AM | #7 |
36
Rep 797
Drives: E92 335, E36 Ti, Porsche 986
I’ve got the exact same wheel size/offset as you and im running 235/35-19 fronts and 275/30-19 Falken fk452's on KW V2 coilovers.
I experimented with both 5mm and 10 mm spacer’s front and back. The 10mm spacers rubbed badly in the back on semi hard turns with the dampening set to about 80% 'hard'. I fit the 10mm fronts, but I didn’t bother to drive the car with them on due to fear of damaging the plastic front fenders. The 5mm's fit fine both front and back with no rubbing issues, so I went with them. I wouldnt chance 10mm spacers in the front, but you could make the rears work with a 265/30 tire, coilovers and a fender roll. Believe it or not, I could visually notice the stance difference with the spacers, even though they were only 5mm's. Here's a pic so that you can get an idea of my ride height and what the offset looks like with 5mm spacers front and back:
Monaco Blue E92 335 - i-Forged Senekas, KW V2 Coilovers, OEM Bmw Aero lip, AFE DCI, LUX H8
Sublime Green Dodge Challenger 392 w/hellcat package. KW Coilovers, Speedlogix CAI Jet Black E36 Ti - E36 M3 drivetrain, Full M-Tech, H&R Coilovers, 3.73 LSD, M-Clubsport interior and much more... |
