Need help: Set the doors to automatically lock.
10-09-2006, 01:14 PM | #1 |
Compulsively abusing the carpool lane
10
Rep 34
I have two key fobs for my 2007 328i. When I use one of them, the doors automatically lock when I get into the car and put it into gear. When I use the other key fob, it doesn't. I assume this is just configuration that can be set. Does anyone know how this is enabled/disabled? |
10-09-2006, 01:21 PM | #2 |
378
Rep 4,320
Drives: '07 Z4 M Coupe
I believe this has to be programmed for each key.
Pop the key that does not automatically lock the doors in, and use the signal stalk to program this setting. Check your owners manual for exact details.
10-09-2006, 01:26 PM | #3 |
1312
Rep 10,185
As said above it needs to be activated for each key
If you have Idrive you can do it on there If you dont have Idrive you do it through the menu on the instrument cluster Procedure is listed in your owners manual Its set for the key that is in the slot when you select the function active
BMW if you are reading, I need a job, Please. |
10-09-2006, 01:28 PM | #4 |
Moderator
318
Rep 17,767
Drives: F36 428i,E90 328i, E85 Z4 3.0i
Its spelled out in your Owner's Manual...
Eack key fob is tied to a specific personal profiles setting...
Official DC Metro Registry - Current, New & Prospective Area Members Roll Call! |
10-09-2006, 02:31 PM | #5 | |
87
Rep 1,032
Drives: 2006 330i & 2010 535i
2006 330i Jet Black w/ Beige Leather/Sport/Prem/Step/Shades/Xenon/Logic 7 |
