Tirerack
The Tire Rack
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > Wheels and Tires Forum Sponsored by The Tire Rack > OZ Ultraleggera 20" M3 Spec on E92 Coupe
      11-27-2009, 03:56 AM   #1
SnMalone
SnMalone's Avatar
Austria
29
Drives: SG 09 E91
I wanted to ask if this would be possible on a e92 coupe:
20x8.5 34 245/30/20 front
20x10 22 265/30/20 rear
on the calculator the fronts will fit perfectly since they stick out the same like the stock 225m 19 inch wheels. but the rear will maybe be too big. even if the car is not dropped it may rub, or what do you think? will rolling fenders be enough?
it says "4mm MORE clearance on the strut side, and the outside edge of the wheel will EXTEND an extra 30mm"
an extra 30mm is pretty much, damn how can i make them fit?
those rims in black would be drop dead gorgeous on an aw coupe.
-- SG 09 E91 --
      11-27-2009, 04:53 AM   #2
enrita
enrita's Avatar
Sweden
161
Drives: 335i - Big turbos
no you will rub like hell at the back .
07 335i AT - MOTIV 750 - MHD E85 BMS flash - BMS PI - JB4G5 - Okada Coils - NGK 5992 Plugs - Helix IC - Snow Stg. 3 - Stett CP - Custom midpipes with 100 HJS Cats - Bastuck Quad - PSS10 - QUAIFE LSD - BMS OCC - Forge DVs - AR OC - ALCON BBK - M3 Chassi - Dinan CP - Velocity M rear Toe arms - Advan RZ-DF - LUX H8 - Level 10 AT upgrade
      11-27-2009, 05:14 AM   #3
remmib
General
remmib's Avatar
Norway
1569
Drives: 2013 F10 520d M-Sport
Yeah, I can't imagine 20x10 ET22 fitting on an e92 without some major fenderwork, even with "only" some 265 tires.
F10 520d M-Sport Alpine White | HRE P43SC 20x9+20x11 | Michelin PSS 255/35+295/30 | KW V3 Coilover | M5 Front Sway Bar + M550d Rear Sway Bar | 3DDesign Front Lip | BMW M Performance CF Spoiler | BMW M Performance Diffuser | BMW M Performance Black Grills | BMW M Performance Pedals |
      11-27-2009, 06:45 AM   #4
SnMalone
SnMalone's Avatar
Austria
29
Drives: SG 09 E91
yeah that's what i expected. then i have to look for something else..only from the width of 10 upwards they have this concave look which makes them really nice. if i only had an m3 to make them fit
-- SG 09 E91 --
      11-29-2009, 01:04 AM   #5
vladster
vladster's Avatar
Slovenia
12
Drives: BMW 335 ci
Maybe you can get a diffirent offset for the rear ?
      11-29-2009, 05:36 AM   #6
SnMalone
SnMalone's Avatar
Austria
29
Drives: SG 09 E91
i was looking for this but it seems that this is the only offset offered in that width and size...
-- SG 09 E91 --
      11-29-2009, 07:02 AM   #7
TigerDejan
TigerDejan's Avatar
Sweden
61
Drives: Bmw 335i Coupe
then you have to pic another wheel
Current:Bmw 325D E90 LCI Edition Sport | BSM | M-Tech | Comfort-Pkg | 6MT | OEM 18" 193M | Alcantara Seats | ESS Tuning Custom Stage 2 | OEM Performance Grill | FK Street Coilovers | CF Emblems |
Sold: Bmw 335i E92 - Fully Loaded - Stage 3+
      11-29-2009, 09:39 AM   #8
Boost Gomez
Boost Gomez's Avatar
No_Country
51
Drives: C63 AMG
2007 BMW 335i  [0.00]
I think it could actually work with enough fender modification.
      11-29-2009, 09:43 AM   #9
enrita
enrita's Avatar
Sweden
161
Go for 19 inch. 20 are way too big for e92.
