5mm spacers on e92 need extended lugs?
11-26-2009, 09:41 PM | #2 |
173
Rep 6,223
they recommand to have extended bolts, but no you don't need extended bolts for 5mm spacers!
2006 E90 Alpine White 330i - Retired
2015 F80 Alpine White M3 |
11-27-2009, 05:48 AM | #4 |
General
1569
Rep 29,202
I would definitely get extended bolts with 5mm spacers.
11-27-2009, 05:50 AM | #5 |
383
Rep 7,952
id get extended lugs as well. anytime you go widening your stance with spacers, its just safer to do so. plus its not like its expensive or anything
11-27-2009, 09:02 AM | #6 |
Ex-CCA racer
Rep 183
Easy enough to measure. You should have as many threads engaged as the diameter of the lug bolt. So if the bolt is 1/2", there should be 1/2" of threads engaged in the hub. Or, if the hub isn't that thick, at least the thickness of the hub mounting surface. Keep in mind you have the thickness of the rotor which is not threaded.
I would not recommend removing 5mm of thread engagement from a wheel except as a temporary measure. Jay
