my car is dead.
11-25-2009, 12:45 PM | #1 |
369
Rep 8,693
Drives: 06 330i
my car is dead.
so i was driving home, and my car overheated 150 miles from my house. it went into limp mode but i had to drive quite a while to a safe place to stop.
warped head or cracked head? why did my car overheat? where did my coolant go? do you think it was an error when i had the head replaced due to ticking valves? |
11-25-2009, 12:50 PM | #2 |
167
Rep 7,433
is there oil in it?
-Brian
2X 2006 BMW 325i [Electric Red & Mystic Blue] | ZPP | V1 | Rear Fogs | M3 Lip Spoiler | EAS RemoteKey | BMS Powerbox | Projector90 Headlights w/ LED AE | LED plate lights | OEM Blacklines http://www.tech-shine.com |
11-25-2009, 12:55 PM | #3 |
Rep 95
I would think the head replacement is a likely culprit. If they torqued the head bolts incorrectly they could warp the head or pinch the gasket, causing it to blow in short order. I'm sure you'll just have it towed to the dealer but if you feel like sleuthing yourself you could check for milky deposits under the oil cap, white smoke from exhaust, obviously less coolant than you had before. All signs of a blown gasket. If the gasket isn't the reason, there are quite a few other reasons if could overheat. Air in the coolant system, bad thermostat, malfunctioning cooling fan. Are you under warranty (I hope)?
E90 AW 330i Sport/Premium/Terra
11-25-2009, 04:17 PM | #4 | |
369
Rep 8,693
Drives: 06 330i
yes, but the sensor is fucked. it always says there is plenty, a quart low, plenty, etc.
thanks! |
11-25-2009, 04:18 PM | #5 |
369
Rep 8,693
Drives: 06 330i
there is no coolant in the tank either
11-25-2009, 04:20 PM | #6 |
369
Rep 8,693
Drives: 06 330i
its already at the dealer. they got it in 45 minutes ago so im waiting for them to tell me what they find by the end of the day, if anything.
meanwhile, im looking for an m3 sedan. |
11-26-2009, 02:06 PM | #8 |
369
Rep 8,693
Drives: 06 330i
its really aggravating. especially with the holiday no one is working on my car.
meanwhile i got a sweet cadillac srx =/ |
11-27-2009, 04:05 PM | #9 |
369
Rep 8,693
Drives: 06 330i
water pump is bad. intresting.
11-27-2009, 04:21 PM | #10 |
General
665
Rep 26,878
Drives: 2-325 330 2-335 2-Z4 2-135 X5d
Dealer's covering everything no problem?
11-28-2009, 09:26 AM | #11 |
369
Rep 8,693
Drives: 06 330i
53 dollars.
11-28-2009, 09:31 AM | #12 |
81
Rep 2,046
what's up with $53?
11-28-2009, 09:34 AM | #13 |
369
Rep 8,693
Drives: 06 330i
deductible from cpo.
i forgot to ask the dealer, and another member of this forum pm'ed me and i dont know the asnwer. where did my coolant go? |
11-28-2009, 09:41 AM | #14 |
172
Rep 2,373
not sure..but since the car has an electric waterpump instead of a belt driven one theres quite a few safety things that happen..ie the car is very sensative to temp so any bit of overheat it usually goes into limp..
11-28-2009, 05:21 PM | #15 |
369
Rep 8,693
Drives: 06 330i
11-30-2009, 10:31 AM | #16 |
10
Rep 329
My water pump just went bad..replaced it and the thermostat...where did the water go i was wondering where mine went as well...not under warranty..1000 dollar fix.ouch
