Tire size question: How wide do I need to go to prevent curb rashing?
11-23-2009, 02:41 AM | #1 |
219
Rep 3,012
So I'm going to be paying for some VS7's tomorrow from a forum member. Overall they appear to be in good condition and I'd like to keep it that way. My first instinct is to go for some cheap tires because I won't be keeping the wheels on for long because a trip up north soon will warrant some winter wheels. But what I'd like to know is what width do I need to run in order to ensure, as best possible that I won't scrape my rim if I happen to accidentally bump a curb while I'm turning or something similar. Basically, I'm asking how skinny can I go yet still have good protection. Thanks!
Also, they are a staggered set. Last edited by klipseracer; 11-23-2009 at 08:46 PM.. |
11-23-2009, 10:11 AM | #2 |
I ask the questions you're afraid to ask.
44
Rep 2,489
Not quite sure that width is the issue. You need a properly sized tire with a pronounced rim protector bead to give you even a bit of protection but there isn't much that'll keep you from damaging your wheel if you scrape a curb.
11-23-2009, 11:20 AM | #3 |
General
1569
Rep 29,202
Stay far away from curbs when you run low profile tires.
11-23-2009, 12:37 PM | #4 |
219
Rep 3,012
Thanks.. I'm not counting on rim protectors because on my 46 I had them and when I rubbed against a curb in a drive through the protector just tore and scraped my wheel anyway. I'm thinking some wider tread would do a much better job at protecting.. Considering it's a verY concave wheel, anyone have a shot in the dark? Any vs7/8 owners that can chime in?
11-23-2009, 01:03 PM | #5 | |
171
Rep 2,057
11-23-2009, 02:12 PM | #6 | |
219
Rep 3,012
How about these: http://www.tirerack.com/tires/tires....omCompare1=yes Here is a review comparing them to the PS2's http://www.m3post.com/forums/showthread.php?t=279362 Last edited by klipseracer; 11-23-2009 at 04:56 PM.. |
11-23-2009, 05:55 PM | #8 |
219
Rep 3,012
Yes, smart one. I am enlightened. Up until your solution I was intentionally driving into curbs. Now it all makes sense, Thank you...
Now, outside of stating the obvious, I will say that I'm not relying on wider tires to stop curb rashing, I'm simply trying to take every possible precaution to keep them in good shape. There will be other people driving my car as well which is something I can't control. One thing about the 245 fronts, should I run something that wide? Wouldn't that cause a little understeer? I'm really more interested in protection than some minor under-steer as I stated i'm not too agressive of a driver. Also, should I run 35's in the back? Or 30's? With a 275 rear end that does make it a bit higher of a wheel. Thanks. Last edited by klipseracer; 11-23-2009 at 08:48 PM.. |
11-23-2009, 06:11 PM | #9 |
90
Rep 1,873
Well, get a tire with an integrated lip protector.
I never understood why anyone would get remotely close to a curb with nice wheels. I'll park 2ft from the curb to ensure I don't accidentally knick it. I would not let anyone drive your car if you're worried about it. Something WILL happen, just because you don't want it to. 275 is the width of the tire in mm. Not related to height of the sidewall. The 30-35 is the sidewall aspect ratio related to the width. |
11-23-2009, 06:39 PM | #10 | |
219
Rep 3,012
11-23-2009, 08:41 PM | #13 |
219
Rep 3,012
Yes, I had 245/45/17's on my eclipse and I've brushed up against the side of a curb a couple times and had no scrapes. Whats your point? Do you really think an extra 3-5mm of extra rubber will hurt my precious wheels? By the way, learn to spell, 'your'. Oh, Obligatory
11-23-2009, 08:42 PM | #14 |
123
Rep 4,249
As others are saying, you'll get little to no protection from curbing regardless of the tire width. Sure, there are folks who like the stretched look where the wheel actually sticks out beyond the widest part of the tire and yes, those would scratch even with the slightest brush against a curb. That said, anything more than a very slight brush against a curb no tire is going to help much with low profile tires.
11-23-2009, 08:44 PM | #15 | |
90
Rep 1,873
11-23-2009, 08:44 PM | #16 | |
219
Rep 3,012
11-23-2009, 08:45 PM | #17 |
219
Rep 3,012
11-24-2009, 01:19 AM | #20 | |
219
Rep 3,012
Edit: nice ride by the way... None haha! |
11-24-2009, 07:58 AM | #22 |
44
Rep 2,489
45 can be 30 or 35 - depending on the width of the tire.
A 205/50/17 has the identical sidewall height of a 225/45/17 or a 285/35/17 as the sidewall height is expressed as a percentage of the wheel width - not an absolute number. Back to the OP's question Tire size depends on wheel width. A 225/45/17 on a 7 1/2 inch wheel will protect the wheel more than the identical tire on an 8 or an 8 1/2 inch wheel although the 225 may technically fit all three wheels. What is the size of the wheel that you are considering? |
