What 19'rear rim offset works good on my 335i Sedan
11-13-2009, 07:48 PM | #1 |
29
Rep 932
Im in the process of pickin up some used rims for my 07 335i sedan. Front rims are ok 35mm offset. But was wonderin if the rear rims would rub they are 19x9.5 with 40mm offset with 265/30/19. Was told they came of a 328 sedan. Need some input before I purchase them.
11-13-2009, 08:30 PM | #2 |
91
Rep 499
Drives: F36 440i
You should have no problems with a 40 offset. You may even want to run a spacer.
11-14-2009, 12:02 AM | #5 |
EUROPROJEKTZ
187
Rep 7,958
Drives: backwards
I'm running VMR CSL reps (19x8.5F +40 & 19x9.5R +30) but I added a 5mm spacer to the front and a 10mm spacer to the rear to make them fit better. My front doesn't look any better with a 5mm so I will be switching to a 10mm or 12mm. My rear with the spacer(10mm) is +20 and they're wrapped in Nitto Invo's (265/30/19) with some rubbing but only when I go over big bumps. So you should be fine with +40 but I say slap on a spacer to push it out more. I would go with a 10mm in the back.
LTMW|SPEEDELEMENT|EUROPROJEKTZ
#TeamStretchNPoke |
11-14-2009, 08:55 AM | #6 | |
23
Rep 366
11-14-2009, 04:02 PM | #8 |
28
Rep 946
I would go with a 15mm spacer. You shouldn't rub even with the 265's what I'm running is +25 offset in the rear. No rubbing ever!
