Replacing Sharkfin Antenna
10-28-2009, 01:42 PM | #1 |
555
Rep 1,244
Drives: 2013 F10 M5
Has anyone had to replace their sharkfin antenna? How hard is it?
I'm pretty sure that my antenna, at least the Sirius satellite antenna is dead and not picking up anything, GPS and FM Radio work fine but Sirius only works in areas where I'm sure there's a ground repeater but outside of cities it doesn't work at all (tell me it's not getting satellite signal, only ground repeater signal). |
11-02-2009, 12:52 PM | #2 |
555
Rep 1,244
Drives: 2013 F10 M5
bump
Has anyone ever had to replace the sharkfin? |
11-04-2009, 07:48 PM | #4 |
555
Rep 1,244
Drives: 2013 F10 M5
Yeah, I checked out the RealOEM page so I know what to expect when I get the cover off. I'm trying to find out what the best way is to get the cover off the sharkfin without damaging the paint on the car and what I need to use to re-glue the cover back unto the car.
11-04-2009, 09:40 PM | #6 |
555
Rep 1,244
Drives: 2013 F10 M5
Cool, so I just need some fishing line to cut the adhesive around the base of the fin, did you use the heat gun at all to loosen the adhesive? Was it held in place with a glue adhesive or something like a 3M tape? What did you use to "re-glue" the fin back to the car?
11-06-2009, 05:35 PM | #7 |
555
Rep 1,244
Drives: 2013 F10 M5
Well, I now know that the sharkfin is the problem with my satellite radio, I hooked up another external antenna and everything is working perfectly now.
Now I just need to figure out which part number I need for a replacement fin and do the swapout. |
06-03-2010, 09:28 PM | #8 |
Rep 241
looks like i am the second person to have this problem....and probably not the last.
frickin dealer wants $400+ the fix the issue so i will be going the Tischer route and DIY the damn thing. |
06-04-2010, 07:36 AM | #9 |
34
Rep 221
I have a question concerning this:
On e90s that were built prior to 03/06 (mine is 02/06), there are two different antennae under the shark fin: one for ground repeater and one for line-of-sight satellite reception Because of this, there are also two antennae wires to connect to the Sirius receiver but my receiver only has one connection, so I'm only connected to the satellite cable right now (it's how BMW does the retrofit since the part with two connections has been on back order for almost 2 years). I'm wondering if I can purchase the 03/06 "guts" and replace mine with that. If I do that, I can just connect the antenna to one of the cables (the one I'm using now) since both the repeater and the line-of-sight are together in one piece. Do you guys think this would work? |
06-07-2010, 02:40 PM | #10 |
555
Rep 1,244
Drives: 2013 F10 M5
k330i,
I've still yet to take that damn sharkfin off and figure out exactly how it's done. So let me know if you try that and how it goes. I'm just using an external antenna for the time being and it's working just fine so there was never a big rush for me to replace the antenna under the sharkfin. |
06-08-2010, 03:48 PM | #11 | |
Rep 241
i ordered the parts from Evan/Jason @ Tischer with my vin so it should be correct. we'll see..... |
06-23-2010, 07:29 AM | #12 |
Rep 241
got it installed last night without any issues
little bit of fishing line to start it and some plastic trim removal tools to finish the job. betalink kit to reinstall and i am good to go free from commercial radio again.... |
06-25-2010, 02:05 PM | #13 |
Rep 71
Drives: 2010 335i X-Drive (E90) (sold)
Not to point you in another direction, but did you check for continuity between the unit and the antenna? I'd hate for you to replace the antenna only to find that it was a wiring issue.
06-28-2010, 11:08 AM | #14 | |
Rep 241
then they quoted me the price to fix it. i said, "nah... that's o.k. i'll do it myself" |
06-28-2010, 03:16 PM | #15 |
555
Rep 1,244
Drives: 2013 F10 M5
I haven't tried to run a continuity test, mainly due to lack of a multimeter, secondly due to lack of knowledge on going about testing continuity on cable.
I probably should try that before buying a new sharkfin, although I am kind of holding off to see if I'd need a new sharkfin for doing a MY2010+ CIC retrofit since it seems the Sat signal is diplexed on the same wire as the GPS going to the CIC. |
06-28-2010, 09:02 PM | #16 |
13
Rep 136
bad reception
My car gets horrible radio reception.
I don't know where to begin to fix it. Could be the shark fin antenna. I also have my windows tinted. I hear the tint could cause interference. The dealer told me nothing is wrong. |
11-04-2012, 02:23 PM | #20 |
Rep 3
Problem with Starmate 8 and Sharkfin on 2009 328i Convertible
I'm new to this forum but have been following this thread to do something similar in my 2009 e93. I purchased the recommended antenna cable from cdint.com--RG174 50 ohm coaxial cable with SMB male and female ends. I found the sirius pink connector on the left side of the rear of the trunk, connected, and got an antenna connection error "check antenna connection" on the Starmate 8. Am i missing something? Fuse? Or does it sound like there is a problem with the pre-wiring? Or the antenna itself? Any other ideas? Any support you can provide is appreciated.
