Extreme Powerhouse
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > AUDIO/VIDEO + BLUETOOTH + Electronics/Alarm/Software > Constant 12+ Volt
      10-28-2009, 12:58 PM   #1
xxvietboizxx
Drives: E92
Constant 12+ Volt
Hey guys,
I'm installing a new head unit on my car and I'mpretty new at this. I pretty much got the basic down with the harness and wiring. However, I heard that I need to run a constant 12+ volt to my new head unit to prevent it from resetting everytime. How will I be able to do this? I recall something about a T-Tap. Can someone please elaborate. Thanks in advance!!
      10-29-2009, 07:44 AM   #2
mrwink2006
Drives: 2006 Apline White 325i Sedan
Need to know Year of vehicle. Some said I wouldn't get a constant from my harness, but I did. I had to tap into the lighter power wire to get my ACC/IGN power. Get the stereo harness adapter from Crutchfield.
      10-29-2009, 09:22 AM   #3
stratplaya06
stratplaya06's Avatar
46
Drives: 2008 E92 335xi-SOLD 5.0 Miata
The fusebox has millions of constant 12v sources. Probe with a multimeter until you find one, use fused link, and connect up. Simple!
| PROcede Rev3 | Vishnu Meth | DCI | BMW Perf. Exhaust | AR Coated/Catless | CP-E FMIC | Quaife |
      10-29-2009, 11:25 AM   #4
grimplinyi
grimplinyi's Avatar
Hungary
Drives: BMW 318d E90
e90
Hy!
an one on button press 12volt where find?
      11-02-2009, 04:00 AM   #5
grimplinyi
grimplinyi's Avatar
Hungary
e90
where find like that +12volt what there is then when the key is within?
I was searching, but I found one like that where you are constant on ignition +12volt.
      11-02-2009, 08:51 AM   #6
xxvietboizxx
Drives: E92
Ok, I ran the constant 12v from the battery to the radio. I did the same with the ground but to the battery ground. Now I have a RED wire that needs to go to the ignition wire. Where can I find that? I thought you can just tap it into the cigarette lighter fuse but when I did that nothing happen and my cigarette lighter doesn’t work. Fuse is not blown either. So I called Kenwood and they told me to connect it to the ignition wire located in the car harness. What do you guys think? As of right now, the red wire is connected to my cigarette lighter fuse using a fuse link. But I have no power at all on my cigarette but everything is else is running fine. Blinkers, wipers, etc.
      11-02-2009, 08:53 AM   #7
xxvietboizxx
Drives: E92
By the way, it's an 09 e92 coupe. Cigarette fuse is 08. After many failed attempts testing out the fuses I gave up and went online and finally found out it was 08.
      11-02-2009, 11:48 PM   #8
mrwink2006
I didn't tap into the fuse box. I tapped straight from the power wire going into the cigarette lighter. You know it only works when the car is on, right?
      11-03-2009, 08:13 AM   #9
xxvietboizxx
Drives: E92
Yeah, I might've mess up something inside my fuse box since my dumb self thought I was suppose to wire it to the fuse box. Now I know I was suppose to tap it into the wire that goes into the cigarette light. Basically it's not the brown one, that's going to ground of course, but which wire should I tap it into? There's total of 3, 1 ground, and one is probably for the power but I'm not sure what the other one is. Now I have to put everything back to stock and bring it to the boys at BMW and have them fix my fuse box LOL. Gotta love warranty.
