Red distribution box on the battery E92 09
10-23-2009, 09:40 AM | #1 |
528
Rep 2,822
Drives: X5M F85
I have a problem. During my amp install the positive wire touched the frame of the car and the amp turned off. The fuse on the amp didnt blow and the amp turns on when i connect the power from point A on the picture. But from point B i am not getting any power. I am guessing there is a fuse i the distribution block, Can anyone verify that? Also what is the rating of the fuse? Thanks
10-23-2009, 10:05 AM | #2 |
528
Rep 2,822
Drives: X5M F85
Ok there is a fuse i checked here ;
http://www.realoem.com/bmw/showparts...46&hg=61&fg=30 Any one know the rating of the fuse? Also in regards the ports where i can plug power cables into the dist. block, Does anyone know what the part number for the plastic piece that i would crimp onto the power cable that goes in to the dist box? |
10-23-2009, 10:41 AM | #4 |
528
Rep 2,822
Drives: X5M F85
There are two things plugged into the box currently, do you know what they are?
Also is it possible that I have only blew the fuse below and not the others?? As that is where the amp was connected. |
