BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > AUDIO/VIDEO + BLUETOOTH + Electronics/Alarm/Software > ciggarette lighter only on when engine on? solution?
      10-23-2009, 03:59 AM   #1
piggelin
piggelin's Avatar
28
Drives: BMW 320i E90 2005
does anybody know how to keep this one on as long as the key is in?
now it will only on when i press start on the start engine button. i wouldnt mind installing oine that can be used all the time in the back seat. since i want to be able to use my dvd and mobile charger all the time
      10-23-2009, 10:18 AM   #2
MunnyGuy
Bimmer Fan
MunnyGuy's Avatar
42
Drives: 2021 BMW M5 Competition
LOL.... I was thinking the same thing as you. Lots of posts but no answers
      10-24-2009, 05:50 AM   #3
Menno11
Member
Menno11's Avatar
South Africa
35
Drives: 320d
2005 320d  [0.00]
Rather hardwire an "add a fuse" circuit and install stand alone 12V socket in the boot. That way you got the power you need!
      10-24-2009, 09:14 AM   #4
piggelin
piggelin's Avatar
28
sorry for being stupid. but how am i going to do that? what parts do i need?
thanks ^^
      10-25-2009, 02:01 PM   #5
stratplaya06
stratplaya06's Avatar
46
Drives: 2008 E92 335xi-SOLD 5.0 Miata
Radio shack has it. Just need unswitched power and a ground. I wired up a few of them in my old car and they worked great. You will need to cut a decent sized hole in a panel, but if you do it on a panel that's cheap to replace it's no biggie.
| PROcede Rev3 | Vishnu Meth | DCI | BMW Perf. Exhaust | AR Coated/Catless | CP-E FMIC | Quaife |
      10-25-2009, 05:40 PM   #6
piggelin
piggelin's Avatar
28
problem is, im from sweden. and we dont have radioshack here. and im not the handiest guy, i just want to make my dvds work when my car is off
      10-27-2009, 04:49 AM   #7
AWM3
BMW Fan
AWM3's Avatar
Drives: 2012 E92 M3, Alpine White
If you don't know how to wire a simple 12V DC circuit you should not attempt to do anything with adding a power outlet to your car. Wired incorrectly the car battery has enough amperage to literally burn the car to the ground - it's happened a number of times to people who rigged up power wires without knowing what they were doing.
It is not difficult to add an unswitched power outlet. You need a fuse holder which will be attached to the positive battery terminal. The size fuse you use will depend on the amount of current you will be drawing. Probably 15 amp or 30 amp at most. You need to know the power consumption of the component that you plan on powering to decide on the appropriate fuse. You also need a 12 volt socket and a length of positive and negative wire, at least 10 gauge wire. The 12 volt socket can be placed wherever you like, then the 10 gauge pos/neg wires need to be routed to the battery where the positive wire will connect to your fuse holder and the negative to the negative battery ground on the car body. If you don't understand everything in these instructions, pay someone to do it for you.
      11-03-2009, 02:32 AM   #8
freshnezzz
65
Drives: 2006 e90
2006 325i  [0.00]
simple solution buy the flashlight cigarette adapter for glove compartment. its like $12 and charges when car is off!
http://www.bavauto.com/fland.asp?par...00%20004%20073
https://lh5.googleusercontent.com/-_8ydeASLoyM/U9XDoM5BjZI/AAAAAAAAVow/5j2M2PHbm4o/w1043-h308-no/DSC_0434-2.jpg
      11-04-2009, 01:13 PM   #9
chch
chch's Avatar
Slovakia
Drives: E91 318i 2008
Can someone show me the picture of the flashlight everybody is talking about ? In my glove compartment there is nothing like that, nor a charging port/dock :-(
E91 318i first registered 12/2007, 2008 model, European.
      11-13-2009, 01:41 PM   #10
chch
chch's Avatar
Slovakia
anybody ?
      11-13-2009, 02:06 PM   #11
Richwm
Richwm's Avatar
65
Drives: 06 E90 330i 6MT, 01 E46 330i
http://www.e90post.com/forums/showthread.php?t=29773 Here is a link to the rear outlets all you would have to do is wire them into a always on circuit.
Mar 05 Build date,2006 E90 330i, Sport Package, Premium Package, TR MT-1's . V-1 Hard-wired power with custom V-1 Concealment Display . Rear fogs, Rear power outlet's, M short shifter knob, BlackLines, BMW Strut tower bar, CDV Delete, Front M3 wishbones + tension struts, BMW Performance shocks and springs, BMW Performance Brake kit F&R, OEM short shift kit. Rear M3 Guide rods and Wishbones.
2006 E-90 330i with 302,000 miles.
