Flat tire warning scared me last night!
09-24-2006, 11:07 AM | #1 |
16
Rep 178
Driving home at 1:30 this morning, the red flat tire indicator light came on. I freaked out and pulled over at a gas station in the middle of the hood to check it out. The air pump didn't have a pressure gauge, so I put some air in every tire, reset the warning light, and drove home. The light didn't come back on the rest of the way home (30 more miles). Was it a glitch?
09-24-2006, 11:12 AM | #2 |
199
Rep 4,178
Drives: E90 325i, E82 135i
I would check the pressure in them still, reseting them needs to be done ONLY when they are properly inflated! You have no idea how low they might be....check the pressure, inflate them properly, and rest the tire pressure sensor again!
09-24-2006, 03:56 PM | #4 |
13
Rep 1,187
Get a tire pressure gauge. Put it in your glove box. Check your tires every two weeks. The life you save might be your own.
First, as long as all four tires go down in pressure together you could be sitting on 4 flats and the system won’t catch it (2006). The system is not meant to replace normal care. Second, even runflats can fail catastrophically if run too long with too little pressure. This is the dying part. |
09-24-2006, 05:26 PM | #5 |
16
Rep 178
I checked the tire pressure today. The fronts were fine, but both back tires were down to 20 psi. I guess that's why the alert went off.
09-24-2006, 05:32 PM | #6 | |
Freude am Fahren
336
Rep 5,254
Freude am Fahren.
Jonathan E90 2006 330xi E90 2006 325i E39 2003 530i Sport* E46 2000 328Ci* E36 1996 328iS* E36 1992 325i* E30 1991 318is E21 1982 320iS* E21 1979 320 (6-Zyl)* *retired Nominated: Most Contributing Member |
09-24-2006, 05:44 PM | #7 |
16
Rep 178
ummm, never. the car is three months old. with these runflats I'll have to be more diligent, since you get no visual indicators from the sidewall
09-24-2006, 06:07 PM | #8 | |
13
Rep 467
09-24-2006, 08:09 PM | #9 |
Smiling politely
165
Rep 7,931
Yup, with the sport pkg, you should be around 32F/36R.
E90 330i Black Sapphire 6MT | 991.1 C4 Platinum Silver 7MT
09-24-2006, 09:35 PM | #11 |
Smiling politely
165
Rep 7,931
You're right. I was thinking 18" on the 330i. 29/32 is recommended for the 17" tires.
09-25-2006, 04:37 AM | #12 |
Commander in Chief
37
Rep 1,034
First, you should inflate your tires to the correct pressures. Then reset the flat tire monitoring system. I would also recommend getting your tires checked for nails or screws. I had one of my rear tires go down to about 25psi, and the dealer found a nail. I had the tire repaired as it only went down to 25psi for the 5 minutes before I filled the tire back to the correct pressure (I keep a pressure gauge in my armrest). Within 15 minutes of refilling the tire, it was repaired.
2008 BMW 535i Space Gray, Black Leather, Dark Bamboo Trim| Sport Automatic with Paddles | Sport Package
2008 BMW M5 (gone, but not forgotten) Space Gray, Silverstone Merino Leather, Madeira Walnut Wood Trim | 7speed SMG | All options Mods: Corsa Exhaust | RPI Ram Air Intake | H&R Sport Springs | Rogue Engineering 12mm spacers |
10-07-2006, 02:30 AM | #13 |
16
Rep 178
Wow, tonight the flat tire warning came on again! Once again, both rear tires were down to around 10 PSI! This is exactly two weeks from the first time it happened. I hope I don't have nails in both back tires. What else would cause this?
10-07-2006, 03:39 AM | #14 |
38
Rep 43
its probably a nail. Bring it to a shop and have it checked out/replaced/fixed and remember to make sure to check ur rims after for chips.
325i TiAg sports xenon auto
10-07-2006, 06:24 PM | #15 |
16
Rep 178
I took it to Discount Tire today, and there nails in both back tires. :mad:
They repaired one, but the other one was too close to the edge. Now I'll be out $300. |
10-07-2006, 11:55 PM | #16 |
Rep 49
both tires heh, look's like someone put those nails purposely, if you know what i mean...
Cheers
MY01 IS300= stock w/ 20% tint. MY00 e39 540 6spd M-package. Stock, but the power is good enough. E90 335i ... Montego with Black leather, 6spd, sport package, cold weather package, trunk spoiler & sirius radio D.O.B.10/09:rocks:, Date of arrival 10/30/06:rocks: . |
