iPod with 6FL option without iDrive?
10-13-2009, 10:17 PM | #1 |
47
Rep 313
I have been reading all the posts about the iPod integration, but I haven't found a specific answer to my questions.
I am getting a 2010 335i sedan with the 6FL option (iPod/USB integration) without iDrive. So, I will just control the iPod with the radio buttons. First, I am trying to find the list of compatible devices with this option, where compatible means the ability to sync _and_ charge the device. I am specifically interested in compatibility with the following iPod models:
Second, is there a place where I can get the manual for the 6FL option? I want to know about the level of control provided, e.g., playlists, search, shuffle, skip, play, etc. Finally, I read recently that the audio from the provided Y cable is horrible even though it is coming from the iPod's line out. Can anyone confirm that? If that's the case, what's the value of this option and what alternative is there to get the best quality audio from the iPod? Thanks! |
10-14-2009, 07:55 AM | #3 |
2288
Rep 13,001
You could always go back to your dealer and ask your salesperson for a 6FL cable and just test your iPods in a car in the lot. Actually, your salesperson should have answered all those questions right there when you ordered the car, as this is simple stuff: get a 6FL cable from the parts department and just get a car with 6FL and let you work it out. You do not even need the keyfob to listen to the music in a non-iDrive car.
This is much better than what you are asking. |
10-14-2009, 08:11 AM | #4 |
21
Rep 1,519
My Mom's iPod with video, no idea what gen it is, works with her non-idrive right through the radio screen. Its a little bit more tedious than mine on the idrive but effective nonetheless. I have never had a problem with the 6FL cable in my car. It works great.
Retired - '08 E90 335i Sparkling Graphite/Gray Dakota Leather, ZSP, ZCW, ZPP, Navi, ipod, Sat
10-14-2009, 08:19 AM | #5 | |
47
Rep 313
I want to buy a new iPod to use with the car, but I want to make sure that either one of the models I mentioned are compatible with the 6FL option. |
10-14-2009, 08:22 AM | #6 |
47
Rep 313
Good to know. Thanks for the response.
10-14-2009, 08:26 AM | #8 |
35
Rep 356
the audio quality was horrible because the track that was playing was a protected drm file and thus is played through aux.
otherwise all the mp3 are streamed through the usb and the sound is excellent |
10-14-2009, 08:29 AM | #9 | |
2288
Rep 13,001
10-14-2009, 10:14 AM | #10 | |
47
Rep 313
Also, the list mentions the following devices as compatible:
However, I see many posts in the forums from people complaining about issues with syncing or charging many devices. So, I just wanted to know from personal experience if the iPod video 5.5 gen or iPod touch 3rd gen worked well with the latest incarnation of the 6FL option. |
10-14-2009, 10:24 AM | #11 | |
47
Rep 313
I thought that if you used an iPod with the Y cable, then everything was decoded by the iPod and sent to the AUX port, and the USB was used only for sync and charge operations. However, if you had a USB stick (or used the iPod as a USB drive), then the BMW audio system would be in charge of decoding the files. Are you saying that only AAC (protected or unprotected) files are decoded by the iPod and sent to the AUX port? Whereas all other formats (or just MP3?) are sent unmodified from the iPod via the USB port to be decoded by the BMW audio system? If any case, I haven't been able to confirm if the BMW audio system does a better job at decoding the files than the iPod, or if it depends on the iPod model. |
10-14-2009, 10:57 AM | #12 | |
2288
Rep 13,001
10-14-2009, 11:39 AM | #13 |
47
Rep 313
10-14-2009, 12:05 PM | #14 | |
2288
Rep 13,001
Like I said before, the best judge is you. Personally, my iPod sounds great thru the 6FL option using 320kps VBR MP3. |
10-14-2009, 01:46 PM | #15 | |
47
Rep 313
I am also aware of the fact that garbage recording = garbage playout regardless of how you connect it. I am more curious/concerned about the dual behavior between AAC and MP3 files where some may be decoded by the iPod and others by the BMW audio system. If the files decoded by the BMW audio system sound "better" than the ones decoded by the iPod, then that means that the BMW audio system is adding some digital filters and enhancements after decoding the MP3 files that are not applied to the analog signal coming through the AUX port with the decoded MP3 from the iPod. |
10-14-2009, 02:49 PM | #16 | |
2288
Rep 13,001
No HiFi system will be available for the MY2010 3-Series. If you use the iPod USB cable then the output is digital straight to the OEM HU and then it follows the D/A conversion as stated above. No DRM songs will play thru this cable. With all that said, the sound quality that you are concerned about also depends on what kind of OEM system your car has. Like I said before and for the last time, the only way for you to find out is to test it yourself in the particular system that you will have. |
10-14-2009, 03:29 PM | #17 | |||
47
Rep 313
I am not interested in subjective audiophile assessments of the quality of the sound. Like I said before, I don't have an iPod to test this. I am trying to decide which one to buy. I just want to understand the facts about the processing of the analog/digital signal from the iPod based on the type of connection made with the audio system. Quote:
Will the non-protected AAC, WAV, FLAC, Apple LossLess, etc. files play as well? Or just MP3 files? More importantly, where the hell is all this information documented? Did you just find this out from personal experience? It would be nice if there was a manual or FAQ for the 6FL option. I don't want to be a pest, but I have searched all over the place and did not find anything. So, I have to rely on this forum for the details. Thanks! |
10-14-2009, 03:37 PM | #18 | |
2288
Rep 13,001
10-14-2009, 03:53 PM | #19 | |
47
Rep 313
For people interested in this subject, after some digging, I was able to find the Service Information Bulletin for the USB Audio Interface here. Last edited by fernande-bmw; 10-15-2009 at 02:59 PM.. |
10-15-2009, 02:56 PM | #20 |
47
Rep 313
Additional USB product information including tested MP3 players, USB devices and mobile phones for new vehicles (as of date of manufacture March 2009 and later) can be found in the attached document.
10-15-2009, 03:03 PM | #21 |
47
Rep 313
I still haven't been able to find details about the internal workings of the analog/digital processing of the Logic 7 system with the USB or AUX ports.
If someone has any service information bulletins or additional documents, please feel free to share them here. Thanks! |
