Let's play 'Will my car start today?'
10-12-2009, 10:58 PM | #1 |
Rep 60
I have to confess that I am a BMW fanboy but this is getting ridiculous. I love my 335xi but 2 weeks ago the nav stopped working so I brought it in to service. It took 2 days to update idrive. The next day I got it back, while driving at night, without any warning, all lights, headlight included, idrive & dash lights all go off! Luckily, we were on a local road lit by streetlamps, so we pulled over and restarted the car. Ever since then, sometimes the car won't start or will start with this message. It's almost enough to make me consider an S4 (haha like that's going to be more reliable).
Notice I'm 8k miles away from no warranty, so maybe I should get rid of it. Any advice? |
10-12-2009, 11:04 PM | #3 |
Where'd my VTEC go?
481
Rep 6,067
10-12-2009, 11:04 PM | #4 |
41
Rep 566
Drives: 2006 330xi 6MT
And what will that solve? It took his dealer 2 days to update idrive, you actually would trust any of their other service this close to warranty end?
Either take it to another dealer or get rid of it before warranty is up. |
10-12-2009, 11:08 PM | #5 |
Bored at work....
891
Rep 5,393
Get it fixed then trade it off.
Grey Matter:2008 E92 M3:608/425. SG/PS SOLD!
Dark Matter:2015 F80 M3:495/505. SOLD! Anti Matter :2016 F82 M4 GTS What next?!? A 2022 M235i GC- I must be getting old |
10-12-2009, 11:09 PM | #6 |
122
Rep 2,090
your not planning to get the extended warranty?
i agree, if you have been having alot problems with your car then its best to just get a new car. |
10-12-2009, 11:14 PM | #7 | |
13
Rep 92
10-12-2009, 11:28 PM | #8 |
Rep 60
Believe it or not, the extended warranty for which I was quoted $3k does not cover idrive! I specifically asked the rep at rallye this, as it's my primary concern with this car. On a slightly positive note, the $2k upgraded maintenance plan will cover my clutch.
10-12-2009, 11:31 PM | #9 |
13
Rep 92
extended warranty have different package. . it come with basic warranty like lube job and brake pad and rotor. other extended package warranty only cover electronic issue.
10-13-2009, 12:26 AM | #13 |
EUROPROJEKTZ
187
Rep 7,958
Drives: backwards
try taking it to the dealer and tell them about how this problem can be life threatening and so on. most likely they will keep your car for like a week to run their "TESTS" and give it back saying we cannot replicate your indicated problem.. but best of luck to you OP
LTMW|SPEEDELEMENT|EUROPROJEKTZ
#TeamStretchNPoke |
10-13-2009, 12:44 AM | #14 |
27
Rep 959
I think legally if you report a problem and bring it in for service before the expiration of your warranty, they need to solve the problem on their dime, even if you continue driving the car past the warranty expiration. It's not fixed until it's fixed.
330xi SG/Terra/Burl -- ZPP, ZSP, ZCW, CA, Sirius, PDC |
10-13-2009, 01:22 AM | #15 |
21
Rep 287
Battery and alternator issues cause a lot of strange problems that show up in the form of random electrical problems. May be the dealer should look at that as well.
Also, the 4x4 problem in my other car (X5) was due to faulty steering angle sensor, that was fixed under warranty at around 45k miles. I was in the same boat as you are with my X5 just last February. I decided that I wasn't going to spend 3-4k on a warranty and will just fix whatever I can myself and have an independent fix other stuff that may go. So far it has worked in my favor. |
10-13-2009, 02:02 AM | #16 |
27
Rep 391
usualyl if u take it in and complain about it, even if they cant find the issue and then ur car goes out of warranty and the issue comes up, you can bitch about it to ur SA and they will goodwill it. I had mutliple oil leaks and they good willed it for me (3 weeks after warranty expried) gl op
10-13-2009, 04:19 AM | #17 |
1706
Rep 14,829
My opinion is that BMW's are designed to be fun to drive, when they're working. I'm starting to doubt that these issues are taking BMW or the dealerships by surprise, they're functioning as designed. There's no way that German engineers are not capable of producing reliable cars, they simply have geared the co. towards leasing and selling extended warranties. So I wouldn't get rid of the car unless you really don't want it. Features didn't disappear over 4 model years while the price went up nearly 4k on a 3 Series, that was by design.
Also, the dealership isn't necessarily the ultimate panacea either. Half the time they don't fix anything and simply state what I did, vehicle performing as designed. So the question becomes can you live with the BMW way or not. If not, then there is the Lexus way. 100% reliability, but less fun to drive. |
10-13-2009, 07:04 AM | #18 |
Rep 49
When that light comes on again (the 4x4 DSC), see if turning the steering wheel from lock to lock a couple times gets rid of it. Sometimes if you're battery goes low, or after programming, it can mess with the steering angle sensor (mentioned earlier). If you take it to the dealer they should fix it and if the problem comes back after your warrenty is expired it should still be honored because they didn't fix the problem when it was under warrenty.
10-13-2009, 07:45 AM | #19 |
Rep 60
thanks for all the advice. I have an appt next monday (earliest appt with loaner) so will see what they say. what i forgot to
mention is that the message goes away after driving a block or 2. it's the sudden malfunction and the non-start ( vehicle behaves like battery is dead but wakes up with a pull on the trunk) that is disconcerting. i had every intention of buying the ext warranty but when they told me that idrive is not covered, i started thinking alternatives. I can't say bmws aren't unreliable, my 04 330 zhp was bullet proof. sometimes it's the luck of the draw. |
10-13-2009, 08:53 AM | #20 |
60
Rep 2,314
I've never experienced those symptoms but I've been driving around with that warning light for the past couple months. It disables traction control (mine is not an xi though).
30k service is next week. Where is this steering control sensor? I have my brake air ducting removed on the front driver side. Do you think they'll give me crap for that not being there? I hit an animal, cracked some of it and removed the ducting (long before i had this error message come up). |
10-13-2009, 10:07 AM | #21 |
1435
Rep 4,724
wow...that looks like fun. Get it fixed!
Current: 2021 M340i xDrive
Previous: '18 340i xDrive; '15 335 xDrive; '14 435i xDrive; '09 335 E92 xDrive |
10-13-2009, 10:35 AM | #22 |
Rep 49
Ianthegreat, I think the steering angle sensor is in your steering column, shouldn't have anything to do with the part you described if thats indeed what is wrong with your car. Audionut, it sounds like you either have a low battery issue, or the car thinks it has a low battery, or maybe a steering column lock problem. I'd be interested in what they find.
