Setting Gain with a voltmeter
09-29-2009, 11:36 AM | #1 |
528
Rep 2,822
Drives: X5M F85
I am setting the gain on my Slash 1000/1 JL. I have followed the steps but i cant seem to get the correct value when i am testing the voltage coming from the speaker output. I am getting a Value of 5.74 instead of 57.4. recommended by JL. I am not sure if the voltmeter is using the correct values or measurments. I have the voltmeter set on auto.
Here is the one i have. http://www.radioshack.com/product/in...ductId=2104114 When i test the battery with the voltmeter set to auto it reads 13.8 which is correct. What value should i be looking for for the amp? |
09-29-2009, 12:40 PM | #3 |
29
Rep 219
Drives: 14 BMW 335xi M-Sport EBII
According to this manual http://rsk.imageg.net/graphics/uc/rs...0820_PM_EN.pdf there is different range for 20V to 200V than with 2V to 20V (which may lead to the difference on your display)
09-29-2009, 01:16 PM | #4 | |
32
Rep 867
"Range Selection The meter automatically selects the best range for the reading. Note the unit of measurement and the position of the decimal point to determine the range. Range Display Range Display 2V d.ddd V 2 k d.ddd k 20V dd.dd V 20 k dd.dd k 200V ddd.d V 200 k ddd.d k " There's no multiplier. The automatic range adjustment just accounts for more precision at lower voltages (i.e more counts per volt @ a fixed bit resolution).
Not only will it kill you it will hurt the whole time while you're dying.
http://www.stevesnovasite.com/ http://www.jalopyjournal.com/forum/ http://www.garagejournal.com/ |
09-29-2009, 02:03 PM | #5 | |
528
Rep 2,822
Drives: X5M F85
Cool thanks! |
