Coby Wheel
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > AUDIO/VIDEO + BLUETOOTH + Electronics/Alarm/Software > "Aux (Front)" Input USB Problems
      09-28-2009, 01:47 PM   #1
Moriarty30
Drives: 2009 335i Sedan
I can't get the Aux input in the glove compartment to read my USB flash drive. It's greyed out on the "External Device" list, but it works fine on any computer I use. Do I need to change a setting? Or remove the ipod (from the center console connector)?
Since I haven't used it, can some describe what should happen when you plug in an external usb drive? You have to import the music, right? You can't play the songs straight from the usb drive like i do on a computer, correct?
Thanks,
M
      09-28-2009, 02:32 PM   #2
scanboy
16
Drives: E90 Montego Blue+Black Int.
have you tried a different USB drive?
      09-28-2009, 02:56 PM   #3
dolby
dolby's Avatar
43
Drives: 2009 e90 M3
Mine is the same way. The glove box USB is for transfering music the idrive.
dolby
- 1998 E36M3/4 (retired)
- 2005 E46 330i ZHP (totaled)
- 2007 E90 335i Black/Blk/Alu Trim (retired)
- 2009 E90 M3 - Jet Blk on Blk mDCT
- 1987 E30 325is - track car conversion in progress
      09-28-2009, 04:04 PM   #4
Evangelo2
24
Drives: 2009 335 m sport Coupe 6-speed
Mine is the same way as well, so how do I transfer the music if I can't select the drive. It's as if it doesn't know it exists! The drive was formatted on a Vista machine and I palced 4 mp3s on it to test. It is a basic no name brand (Microcenter) 4GB USB thumbdrive. Any reports on what thumb drives work well?
-Evangelo2
Previous Car: 2002 M3 Coupe 6MT
Previous Car: 2006 G35 Coupe 6MT Fullly Loaded
Current Car: 2009 335 Coupe, 6MT, Black Sapphire, Saddle Brown, M Sport, Cold Weather, Premium, CA, Nav, L7, iPod, Smartphone Adapter, Sirius
      09-28-2009, 04:26 PM   #5
David1
David1's Avatar
No_Country
814
Drives: 09 E92 09 X5
From what my tech told me is that you should use a new stick and only use it for the car and also have a seperate stick for a back up.. For some reason if you format it, many of the cars will not see it for some reason.
2021 M2 Comp Sunset Orange |Black with orange Stitching Dakota Leather|Executive Pkg|DCT
      09-28-2009, 05:26 PM   #6
Thunder Dump
That tickles
Thunder Dump's Avatar
Drives: '09 328i E93 SGM/CR
It needs to be formatted FAT or FAT32. If it's formatted as NTFS the car will not see it.
      09-29-2009, 11:38 AM   #7
Moriarty30
No dice. Neither FAT nor FAT32 works. The only other solution offered above is to buy a new stick, but I'm not convinced that can solve the problem.
David1 - I don't understand how only using it in the car can fix the issue, since i'd have to connect to my computer at some point in order to copy music to the drive.
      09-29-2009, 10:02 PM   #8
Evangelo2
24
+1 on this.
I had it working at some point. I have to look into fomratting as FAT32. I have a bunch of USB sticks lying around and Im sure some are NTSF.
      10-07-2009, 10:28 AM   #9
Evangelo2
24
Well, tried formatting as FAT32 and no luck. This stupid USB port in the glove compartment no longer reads memory sticks. Annoying. Ill have the dealer look into it next month when I bring it in for an oil change...
