What is the E9X's alternator's Amp rating
09-17-2009, 02:20 PM | #1 |
528
Rep 2,822
Drives: X5M F85
As the title say, what is the amp rating?
09-17-2009, 04:01 PM | #2 |
2288
Rep 13,001
09-18-2009, 02:07 AM | #3 | |
220
Rep 2,339
2016 Porsche Cayman GTS - Sapphire Blue / Black Full Leather Interior / Carrera S Wheels
09-18-2009, 11:28 AM | #5 |
528
Rep 2,822
Drives: X5M F85
Thanks for the link. So 170 - 180 amps. I am added a JL 1000/1 and an extra battery. The car is having touble kicking over when i let it sit for like 2 days without driving, the amp is also showing a low voltage indicator when i push the bass.
Technic, Should the stock alt be able to charge both batterys? Thanks |
09-18-2009, 12:26 PM | #6 | |
2288
Rep 13,001
09-18-2009, 01:25 PM | #7 | |
528
Rep 2,822
Drives: X5M F85
Also could you please reccomend a deep cycle battery, and how i can install it, i cant remember exactly but it seemed as if the oem battery has two positive outputs, well not two positive outputs but a red device connecting a few wires to the positive terminal. Can you explain what the red contraption is and what do i do with it when i replace the battery. Thanks Let me know thanks. |
09-18-2009, 01:43 PM | #8 |
13
Rep 390
Drives: BMW E90 33?i | 90 Integra B20
If the battery cant hold up for 2 days then either something is not shutting off properly and draining your battery or the battery is no good, stock battery should be able to hold a good charge with the system off, just make sure you have a good cap on your system and you should be ok. I have two fosgate 600 RMS amp and a 20 farad cap with stock battery and have no problems and I only drive my car on the weekends so it usually sits for 4-5 days every week.
|33?i e90|Platinum Silver black leather w aluminum trim|6spd|Sport|Premium|Mtec v3|Rockford Fosgate System| |2015 Lexus IS250 AWD|Pearl White w Tan int|Premium|Navi| |2000 integra DC4|Silver Gray int|5spd|B20 Motor| |
09-18-2009, 10:33 PM | #9 | |
220
Rep 2,339
09-19-2009, 11:29 PM | #10 | |
528
Rep 2,822
Drives: X5M F85
09-20-2009, 02:34 AM | #11 |
220
Rep 2,339
Something is definitely wrong. That is not normal.
09-20-2009, 12:56 PM | #12 |
300
Rep 3,969
I'm no electrician but I have never thought a second battery is a wise investment. In my mind the amp draws power from the second battery (12V) instead of the alt (14-15V). Then when you shut off your car, the second battery which has been drained by the amp now tries to recharge from the main battery.
Try to disconnect the second battery and see what the voltage drop is then. It may be better if you go with a single deep cycle battery (Optima or equivalent). If you're still having trouble then you may want to look into a "big 3" upgrade, which is relatively inexpensive, and/or a more costly alt. replacement. |
09-21-2009, 08:58 AM | #13 |
528
Rep 2,822
Drives: X5M F85
I went everywhere trying to figure this situation out and no1 had an answer that made sense to me. They looked at my battery and said, " thats huge, its more then sufficient." And when i told them my alt was rated at 170-180 amps they said that wasnt the problem. The 500/1 was causing my car to have long cranks but the bass never cut off. Then when i upgraded to a 1000/1 the car still showed the same symptoms, long starts not longer or more frequent but the same as when i had the 500/1 installed. The voltage at the amp is droping, i would attribute this to poor wiring but the car is still having long cranks which makes me think the problem lies with the stock electrical system. My guesss is that my original battery is not holding a charge as long as it should. Could this be because i drive the car once a week and when i drive i am always pumping the amp at least 75%? Is my original battery bad?
09-21-2009, 09:12 AM | #14 | |
2288
Rep 13,001
There's not that much else to it. |
09-21-2009, 09:16 AM | #15 | |
528
Rep 2,822
Drives: X5M F85
Actually i just reread your first recomendation, please let me know which battery i should get, i want this situation to be done with ASAP. Thanks |
09-21-2009, 09:40 AM | #16 | |
2288
Rep 13,001
09-21-2009, 10:14 AM | #17 | |
528
Rep 2,822
Drives: X5M F85
Nevermind the Stinger is rated at 525amps 35ah. So Optima it is. Im not sure which battery i have, No. Description Supplement Qty From Up To Part Number Price Notes 01 Battery Fa. Douglas (Warranty only) 70AH 570A 1 61218381738 $153.75 01 Battery from Exide (Warranty Only) 70AH 570A 1 61217586960 $192.50 01 Battery AGM 12V 90AH/900A AGM 70AH 760A 1 61217553951 01 Battery Fa. Douglas (Warranty only) 80AH 640A 1 61218381749 $170.00 01 Battery from Exide (Warranty Only) 80AH 640A 1 61217586961 $212.50 01 Battery Fa. Douglas (Warranty only) 90AH 720A 1 61218381762 $180.62 01 Battery from Exide (Warranty Only) 90AH 720A 1 61217586962 $235.00 01 Battery AGM 12V 90AH/900A AGM 90AH 900A 1 61217553954 $307.50 |
09-21-2009, 10:24 AM | #18 | |
2288
Rep 13,001
That's what you need to find out first before doing anything else... the P/N should be printed on top of your OEM battery. |
09-21-2009, 10:27 AM | #19 |
528
Rep 2,822
Drives: X5M F85
09-23-2009, 11:34 AM | #20 |
528
Rep 2,822
Drives: X5M F85
Ok Technic and others helping,
Im going to go the route of a battery isolator, Which one do you recomend, http://cgi.ebay.com/ebaymotors/STING...=p4506.c0.m245 or http://cgi.ebay.com/STINGER-SGP38-HI...4.c0.m14.l1262 And how to i hook these up, Posi from isolator to Posi on primary battery, Posi2 from isolator to posi on Aux battery Smaller output from battery isolator to ground Second smaller output to ???? a true ignition source, whats that? |
09-23-2009, 12:02 PM | #21 |
220
Rep 2,339
Before you go through the whole exercise of buying a dual battery setup, have you ever checked the wiring for the amp? When you changed from the 500/1 to the 1000/1, did you redo the wiring or did you just swap out amps? It really seems to me that you have a wiring problem that for some reason is killing your battery. If your battery is not holding a charge anymore then you'll need to buy a new one anyway but I'd rather not see you buy a new one only for it to die in a month or so because the problem is still there.
What happens if you disconnect the amp for a couple weeks? Does the battery hold its charge longer?
09-23-2009, 12:50 PM | #22 | |
528
Rep 2,822
Drives: X5M F85
