Removing Sirius Satellite Box Help
09-13-2009, 04:53 PM | #1 |
422
Rep 8,003
Drives: '08 E90 335i, '99 E36 M3
Hey guys,
It seems my Sirius subscription ran out. The thing is, I never even use satellite radio so I was thinking of removing my satellite receiver box from the left side of the trunk and put it up for sale. I tried removing it earlier today. I'm sure I removed the right box - it had a black cable and a pink cable connected to it and said Sirius DLP 2.5 on it. I removed the cables and the box. However, upon starting up my car again, I got a SOS malfunction, the Bluetooth didn't work and my radio didn't work. Plugging the black cable and pink cable back into the Sirius receiver made everything work again. How do I go about removing it without the errors? Thanks. |
09-13-2009, 05:08 PM | #2 |
21
Rep 339
just taking the module out creates a break in the fiber loop that it, and the tcu, head unit, etc, is connected to.
You will have to reconfigure the fiber connections to remove the unit from the loop. The fiber jumper block is behind the rear seat back on the driver side. (or just the rear seat back cusion on the driver side if you have split fold down back seats. ... or you could leave the sat module in the loop. |
09-13-2009, 06:56 PM | #3 |
422
Rep 8,003
Thanks! Is there a DIY for it or do I need to get my hands dirty?
09-13-2009, 08:00 PM | #4 |
21
Rep 339
There's a DYI on how install a sat radio module with the bmw tech instructions in pdf form.
hint - use a flashlight to light up the fiber from the sat module to find them. When re-connecting the fiber cables just think *loop* One more thing - I do not know what will happen with the sat module out but still prgrammed to look for it. You get another error because it's gone. Perhaps a lurking tech can provide an answer. |
09-13-2009, 09:01 PM | #5 |
NY Yankees #1
146
Rep 1,174
Drives: 2010 AW E92
If your looking to sale the Sat. PM me. If it will work in my E90 I'll take it.
09-13-2009, 09:09 PM | #6 |
Rep 30
also interested
Also interested in the sat module. Let me know what kind of price you are thinking about.
07 E90 335i Jet Black / Black Dakota / Sport / Performance / 19" Beyern 5's / Conti DWS / StopTech rotors / Cool Carbon / Procede / 6 spd MT
09-13-2009, 09:14 PM | #7 |
422
Rep 8,003
If I can remove it without any errors, I'll sell it. I'm still trying to figure out how to re-connect the MOST loop.
11-08-2009, 04:29 PM | #9 |
422
Rep 8,003
I'm having trouble accessing the MOST distribution block. I don't have folding rear seats. How do I get to it?
11-08-2009, 09:58 PM | #10 |
Rep 60
You have to remove the rear seat bottom first. If I remember correctly you just pull up the front edge and it unsnaps, then you can pull the bottom out of the car completely. Then you have to remove the seatback. There are two T40 (I think) bolts at the bottom they're towards the middle of the seat, unbolt those. Then in the roof of your trunk there are two latches, one on each side that release the seatback. You'll probably need to lay on your back in the trunk looking at the roof to find them. After you've got the seatback removed the MOST distribution block is on the drivers side, you can't miss it. Sorry I haven't been down that way, I just got offered a job up here that I couldn't pass up. If you're ever up this way I'd be more than happy to help. I'll be in town for the Holidays though. If you want to wait that long I'd be more than happy to lend a hand.
2011 335i LCI Sedan, Sapphire Black, Oyster Dakota Leather, Premium, Cold Weather, Sport w. Paddles, iDrive, iPod, Premium Sound, Comfort Access.
11-08-2009, 10:01 PM | #11 | |
422
Rep 8,003
I found the two bolts earlier today. I removed one of them but the other one was torqued down very tightly so I couldn't make it budge. I think I stripped some of the thread too. I was hoping there would be an easier way, without having to remove the bolts. I'm going to get a longer wrench and try again next weekend. |
11-08-2009, 10:02 PM | #12 |
361
Rep 5,873
Drives: m
Dang! All that work just to remove the sat box?? I popped mine out of my gti in seconds with no errors or issues. Thats crazy.
Nivedh - you should make a diy of removing the box cause id like to take mine out since I dont use sat. Maybe its different on an 09 though, idk.
11-09-2009, 09:41 AM | #13 | |
422
Rep 8,003
Ok, I'll take pictures of the entire process. I just wish I were strong enough to remove that one bolt. I'll get a bigger wrench and try my hand at it this weekend. |
11-09-2009, 04:08 PM | #14 |
Rep 60
Yea, mine were in pretty tight too. Once you get to the MOST junction box it's fairly easy. I used a flashlight to identify the cables, made it much easier. Remove the now defunct cable from the loop and you're good to go. My iDrive still shows the satellite radio as an option, it just gives an error when you try to access it, no biggie.
11-09-2009, 05:34 PM | #15 |
General
8209
Rep 18,823
Drives: BMW
All that's needed is a termination loop, here's a diagram:
source: http://www.realoem.com/bmw/showparts...78&hg=61&fg=15 You'll need #12 & #7
Tom G. | european auto source (eas)
email: tom@europeanautosource.com · web: https://europeanautosource.com· tel 866.669.0705 · ca: 714.369.8524 x22 GET DAILY UPDATES ON OUR BLOG · FACEBOOK · YOUTUBE · FLICKR · INSTAGRAM |
11-09-2009, 05:37 PM | #16 |
Rep 60
It's easier to just close the loop by rearranging the cables so that the two now unused cables line up with each other. No additional parts are needed.
11-09-2009, 05:38 PM | #17 |
361
Rep 5,873
Drives: m
Is there anyway you can spell that out for us non technical folk. Like tell me specifically what to do. Thanks
11-09-2009, 05:41 PM | #18 | |
General
8209
Rep 18,823
Drives: BMW
The parts are about $10 from your local dealer.
11-09-2009, 05:56 PM | #19 |
Rep 60
Once you have access to the MOST junction box take a flashlight and shine it into the satellite radio wiring harness in the trunk. Position it so that it's right up against the cables, remember you're trying to get the light from the flashlight to shine into the cable. Once that's in position remove cables from the MOST junction one at a time, if there is no light illuminating from the cable (it'll be faint but fairly obvious) simply put it back, if you identify one that's lit note its position. Then on the opposite side of the junction box (top or bottom) find the other cable that's lit, move it in the junction box so that it lines up with the other lit cable, I don't believe the position of the cables matters as long as you have live cables going to other live cables. I moved my two now unused cables to the far right end of the box. I think I also had another two dead cables in there that I had to realign (maybe an option I don't have?). If the car is on you should have all the live cables pointing to other live cables. I BELIEVE this is correct, it's been a while since I've done it. If you guys have trouble PM me and I'll go check mine out again.
11-10-2009, 04:35 PM | #20 |
422
Rep 8,003
So if you use the termination loop, I can just add that to the unplugged wire from the satellite box? Which means I don't even have to access the MOST block?
11-10-2009, 05:06 PM | #21 |
General
8209
Rep 18,823
Drives: BMW
Correct - no need to overcomplicate things.
11-10-2009, 05:07 PM | #22 |
361
Rep 5,873
Drives: m
So id unplug the sat box, leaving all the wires in tact. And pop on those two pieces you mentioned before. Thats all?
