Extreme Powerhouse
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > AUDIO/VIDEO + BLUETOOTH + Electronics/Alarm/Software > Door Speaker Wiring -- using OEM connector?
      09-08-2009, 12:47 AM   #1
Quasimodem
Quasimodem's Avatar
147
Drives: 335d
2009 335d US  [0.00]
So I am installing a CDT Audio HD-42 - 4" HD Series Component System in my doors. I found a set of pins which allow me to adapt the OEM connectors to conventional wires which will then go to my passive cross over.
But the pins look very small. I want to leave everything as stock as possible so just plugging into the existing connector is ideal. But the pins are so small that I am wondering whether using the existing connectors will create a bottleneck in my system at the connectors.
Ideas?
      09-08-2009, 01:57 AM   #2
VP Electricity
VP Electricity's Avatar
289
Drives: F34 xDrive
Why not leave your factory wires alone? Pulling new speaker wire into my E91 F doors was a lot easier than, say, an Acura TSX.
      09-08-2009, 06:07 AM   #3
Technic
Technic's Avatar
2288
Drives: 2021 i3S, 2024 i4 M50
Ideas?
You have a more important concern other than the pins... those 4" will not fit behind the OEM grilles, they are too deep.
      09-08-2009, 12:39 PM   #4
Quasimodem
Quasimodem's Avatar
147
Drives: 335d
2009 335d US  [0.00]
Ahh, just like the BMW engineers, you underestimate my ingenuity.
I spent a lot of time this weekend drilling the aluminum brackets I am installing on the inside of the doors which will allow me to top mount the speakers. I will post pics when they are done.
      09-08-2009, 12:58 PM   #5
Technic
Technic's Avatar
2288
I did not say that you cannot top mount these speakers, I said that you cannot bottom mount (behind the OEM grilles) these speakers...
      09-08-2009, 01:37 PM   #6
Quasimodem
Quasimodem's Avatar
147
Drives: 335d
2009 335d US  [0.00]
Yes, but the genious is that I am top mounting them without drilling holes in the door panel. yes I will have to make a custom grill.
The OEM speakers use the depth of the panel because their brackets are recessed back from the front of the speaker. So if you don't top mount, you are losing like a half an inch in depth which the OEM speakers are designed to take advantage of.
      09-08-2009, 01:41 PM   #7
badfish
badfish's Avatar
100
Drives: E92 AW M3
2008 M3  [0.00]
Spelling error, genius
      09-08-2009, 04:19 PM   #8
Quasimodem
Quasimodem's Avatar
147
Drives: 335d
2009 335d US  [0.00]
A claim on my part to be a good speller would be disingenius.
      09-08-2009, 08:34 PM   #9
AWM3
BMW Fan
AWM3's Avatar
Drives: 2012 E92 M3, Alpine White
Ideas?
Just cut the wires a few inches back from the OEM connectors and then reattach them later if you need to.
Or wrap the connector/pin assembly with bare copper wire before insulating it which effectively will increase the gauge of the wire at that point by providing more conductive material.
Or don't worry about it. The voltage drop across that short little connector is going to be very small and insignificant. You can get away with passing a lot of current through a small wire for a short distance - you have problems the longer the wire gets.
      09-08-2009, 10:48 PM   #10
Quasimodem
Quasimodem's Avatar
147
Drives: 335d
2009 335d US  [0.00]
Cool, forgot about that. Thanks.
      09-12-2009, 02:14 PM   #11
Quasimodem
Quasimodem's Avatar
147
Drives: 335d
2009 335d US  [0.00]
So my devious plan to top mount the CDTs is coming together. We shall see...
      09-14-2009, 12:55 AM   #12
Quasimodem
Quasimodem's Avatar
147
Drives: 335d
2009 335d US  [0.00]
One in. Couldn't figure out how to get the sail panel off so I couldn't do the tweeter. Another research project.
      09-14-2009, 02:39 AM   #13
scampos1984
Spaniard member
Spain
Drives: E90 & E91 320d
Looks great, how it is the sepaker grill?
      09-14-2009, 10:43 AM   #14
Quasimodem
Quasimodem's Avatar
147
Drives: 335d
2009 335d US  [0.00]
I am going to have to adapt the OEM grill. The one that came with the speakers pushes the speaker out farther and then the grill extends out even farther which would hit the dash.
      09-14-2009, 05:06 PM   #15
scampos1984
Spaniard member
Spain
We'll see the result
      09-26-2009, 01:04 PM   #16
Quasimodem
Quasimodem's Avatar
147
Drives: 335d
2009 335d US  [0.00]
Arghhhh. I just tried to gain access to pull a new speaker wire into the drivers side door. I found out that the electrical connector on the e90 doors are almost hermetically sealed. There is no way to get a wire in there without adding pins to the door connector or messing up the waterproof cover for the harness.
Back to using OEM wires.
      09-26-2009, 01:35 PM   #17
VP Electricity
289
Drives: F34 xDrive
I didn't add pins and I didn't mod the connector.
Did you take the boot off? There was a huge passage at the bottom of the connector on the sill side. I pulled Pear Cable Comice in there - as big around as your little finger, OD more like a 16GA extension cord. I put a little hand soap on it to help pull it through the Z-shapped rubber boot, but getting it through the connector was not a deal.
The driver's side wire passage in the kick is blocked by a module. I took out a bolt temporarily to get the wire through.
The passenger side passage was not blocked.
Both passages were plugged with gray foam plugs with a notch for the wire.
Would you like me to take pics of how to do it and post them?
      09-26-2009, 02:29 PM   #18
Quasimodem
Quasimodem's Avatar
147
Drives: 335d
2009 335d US  [0.00]
Thanks, I don't need the pics, I get the idea, although it probably wouldn't hurt for others to be able to see it. I did have the connector off didn't notice any passage, it must have had the plug in it. And I gave up and put all the trim back together again. Yes I saw that module sitting there in my way too, all a bit discouraging. I will pull that connector off again and look for the passage, thanks.
      09-26-2009, 03:18 PM   #19
Quasimodem
Quasimodem's Avatar
147
Drives: 335d
2009 335d US  [0.00]
I don't see any passage in my connector. There is a gap in the sheet metal, but no way I see to get a wire through it without drilling the top portion of the plastic housing where the white dot is.
      09-26-2009, 06:03 PM   #20
VP Electricity
289
Drives: F34 xDrive
The connector is not as long as the boot opening. I ran the wire at the bottom of the boot - as close as possible to the corrugated boot itself - and drilled no holes.
If you were pulling standard lamp-cord-style speaker wire rather than the cable I pulled, it should be even easier.
      10-03-2009, 10:55 AM   #21
Quasimodem
Quasimodem's Avatar
147
Drives: 335d
2009 335d US  [0.00]
Well, they sound pretty good. Haven't made the covers yet, but considering what I had to do to install the midranges without drilling the door panels, the covers shouldn't be a problem.
      11-23-2012, 07:31 PM   #22
starbai
PPRSWCE
starbai's Avatar
Guyana
654
Drives: 18 Tanzanite Blue F80 ZCP
I know bumping a thread this old is a forum etiquette no no... but did you ever fabricate the grilles? got pics?
