How to remove rear center brake light?
09-14-2006, 11:04 AM | #1 |
Rep 69
Can someone help?
I remove plastic cover (panel) (pic 1) But dont know how to remove the light... (pic 2) |
09-15-2006, 05:04 PM | #3 |
Rep 69
I have a rattle coming from the light. I can move the light left and right but cannot remove it from the window, so maybe it is glued. Thanks man. Ill try to fix it somehow.
10-15-2006, 08:13 AM | #4 |
Larry from Los Angeles
14
Rep 296
I have the same rattle. There is something loose inside rattling around. IT is driving me crazy. I can't quite understand your instructions to remove the gray cover. Do you pull down from rear and then side the panel back toward the back of the car?
To replace, do you slide it back and then push it UP ? Don't want to break anything. Thanks. Larry in Los Angeles |
10-15-2006, 10:24 AM | #5 |
241
Rep 2,453
I have the answer!
Just happened to have removed this light about a week ago because for some reason the glass inside of it got dirty (foggy) and I had to clean it out. There are two black clips on each side of the light. Looking up at it from inside the car you'll see the clips. Slide the one on the right to the right and the one on the left to the left. It takes a bit of force, at least it did for me, and the clips slide off and then the light assembly comes right off. To put back up simply hold the light assembly in place and slip the clips back on and push to lock them in place. |
10-15-2006, 10:26 AM | #6 | |
241
Rep 2,453
10-15-2006, 12:26 PM | #7 |
335
Rep 2,385
I need to get in there too. The tint shop got soapy water in there so it looks all nasty. I've just been lazy/waiting for clear instructions haha.
What type of tool did you use to slide the clips off?? Flathead?
retired 06 E90 325i New: 09 VW Platinum Grey Jetta Sportwagen 2.0T SEL w/DSG, panoramic sunroof and Ipod adapter |
10-15-2006, 04:02 PM | #8 | |
241
Rep 2,453
The tool to use: Your thumb and index finger. |
02-05-2013, 09:15 PM | #9 |
1477
Rep 409
Thanks to DJ & this old thread, I was able to sweep out a bug that died inside the brake light compartment. And dust up!
'08 335xi (E90), 6MT, Arctic/Black, ZPP, ZSP (18"s), ZCW, CA, PDC, i-Pod
Ordered-March 7, 2008, Shipped via Graceful Leader-March 21, 2008, Arrived Port Hueneme-April 11, 2008, Delivered-April 21, 2008 |
