My hifi system - Head Unit to Amp wires different.
09-06-2009, 11:36 AM | #1 |
52
Rep 883
On My LCI-
No longer are the wires from the HU to the amp the same as all the wiring diagrams on this forum Now there are combinations of grey, green, purple... ANd no Brown orange as ground.. Any one have an updated diagram... More shit to go wrong, yay! |
09-06-2009, 12:22 PM | #3 |
289
Rep 3,201
Good info.
You cite one of the reasons I stopped posting colors. They change (I answered wire color questions for car alarms for years, I know : ) Good job finding them. You can always test with a voltmeter and your fade and balance controls. You can always test the speaker outputs in a similar fashion, but with a small battery after you've identified the pair of wires as having a voice coil impedance across it... |
09-06-2009, 01:29 PM | #4 |
52
Rep 883
Speaker outputs remain the same...
No matter what I do with the balance and fader - ALL of the inputs read +5v (~.5v) Ive given up and just bought line output converters. |
09-06-2009, 02:09 PM | #5 | |
289
Rep 3,201
If the fader is working and the voltmeter isn't displaying the change, then your use of the voltmeter is the issue, I'm afraid. I'm sorry that you seem discouraged, but I have no idea how LOCs will solve your problem, either. |
09-06-2009, 03:47 PM | #6 |
52
Rep 883
I got it installed and sounds great...
I left the factory amp in, Pulled the remote turn on signal wire off the factory harness. Pulled the High level outputs from the factory amp out, into LOC's then used the low lwvels form the LOC's for my Amp. VP- the speaker OUTPUTS from the amp were chaging.. But the signal from the factory head unit to the factory amp never budged. Maybe I was doing it wrong as Im not an expert.. But 40 bucks worth of LOC's solved my problem by grabbing the factory amp outputs. Your Morels sound great... I like them.. Right now car has- Factory HU Morel Dotech 4" / Tweeters up front (I set the crossovers to +3 on the tweeters by the way - not sure if thats right but I like it) Factory rear speakers (may replace with infinity) Earthquake SWS-8 under the seats Apline PDX-5 It s VAST improvement over the stock Hifi system. |
09-06-2009, 04:04 PM | #7 | |
2288
Rep 13,001
