Where to get remote turn on for an amp?
09-04-2009, 10:42 AM | #2 |
2288
Rep 13,001
09-05-2009, 08:53 PM | #3 |
Rep 4
Well.. I have the OEM HIFI amp and trying to get the remote for my extra amp from the pin 10. Yes I checked the pin 10 with meter. It gives you 12 volts remote, which goes off few minutes after turing off the car. BUT, I couldn't find the pin10 wire (thin black wire). Should I open the whole socket and connect a wire to it? THNANKSSSSSS |
09-05-2009, 09:43 PM | #4 | |
2288
Rep 13,001
Just tap that wire, no need to open that connector. If that wire cannot turn on your amp then you will need to use a relay -search for the schematic on how to use a relay with that wire, I posted it some time ago. |
09-05-2009, 10:15 PM | #5 | |
Rep 4
But as I said there is not any wire connecting to the pin 10. Should I open the connector and wire it out? |
09-05-2009, 10:21 PM | #6 |
2288
Rep 13,001
09-06-2009, 05:30 AM | #8 |
BMW Fan
Rep 553
That thin black wire is about the thickness of a human hair. I don't know why they couldn't have used an 18 gauge wire, for strength and reliability if nothing else.
03-27-2010, 05:51 PM | #9 |
47
Rep 710
Is the thin black wire connected to the amp or HU? I don't want to run wire through the cabin and take out the HU (i am lazy).
03-27-2010, 07:55 PM | #10 | |
2288
Rep 13,001
There's no remote signal at the OEM amp (digital message turn on thru MOST). |
03-27-2010, 08:01 PM | #11 |
47
Rep 710
thank you technic. i've been looking for a DIY on how to remove the HU. got a link?
03-27-2010, 09:11 PM | #12 |
2288
Rep 13,001
03-27-2010, 09:48 PM | #13 |
253
Rep 7,089
Drives: '06 AW 330xi
Take out the AC controls, remove the radio faceplate, then unscrew the 4 philips head screws. Removing the harnesses/wires in the back can be tricky. The main harness has a lever that you flip down.
03-27-2010, 10:11 PM | #14 |
47
Rep 710
haha you're all over this subforum aren't you? thanks for being you.
03-27-2010, 11:22 PM | #15 |
253
Rep 7,089
No problem. I was once in the same boat as you...like 6 months ago. I'm just contributing back what the community gave me and I'm still learning more everyday.
