330i: oil, diff, & tran fluid change at 1700 mi OK?
09-05-2006, 11:17 PM | #1 |
newbie.
18
Rep 83
I know that the service question has been debated, but Dr. Google and e90/bmw/3series forum searches don't really yield much info.
I am considering getting a complete fluid change for the reason of the the break in results in metal shavings. My only question that I cannot get answered is: Are there any possible negatives to this early service other than cost? Are there any "special" fluids. I cannot get an answer from multiple service advisors. Though one who hinted that they can only recommend the scheduled service intervals. Thanks, Yzandrl |
09-06-2006, 03:26 AM | #2 |
38
Rep 1,238
No negatives. The engine will never be harmed with fresh lubricants. But do realize that the transmission fluid is permanant in a BMW. You can't change that. Regarding the engine oil, some people prefer to change it after break-in while some chooses to change at 5000 miles or so. But if you trust BMW, you change the oil when the OBC tells you to.
09-06-2006, 04:32 AM | #3 |
Got Seoul?
116
Rep 2,862
Drives: 2012 535i MSport
Exactly! No need to change the trans oil since that was something that owners did in the past models. The E-90 doesn't need that. The oil is a personal choice.
Can you say Alooooha?
[SIGPIC][/SIGPIC] |
09-06-2006, 07:05 AM | #4 |
144
Rep 1,184
Eh, its BMWs definition of lifetime, aka lifetime=the warranty period they are responsible for.
No harm in changing any of the fluids, although I can tell you the differential has no drain plug even, so you will either have to remove it and tip it over to drain it from the fill plug, or figure out some other way to get the fluid out. The trans still has a drain. |
09-06-2006, 10:33 AM | #5 |
newbie.
18
Rep 83
I can schedule the transmission, differential, and oil with North Scottsdale BMW. The other dealerships said they would NOT do it for the Diff or Trans.
This dealership said they would do it; just that it would cost me about 600+ish for it. Including the fluid costs about $40/qt and I need about 8 qts. I understand its a lifetime transmission fluid..etc.. But does it cause any potential harm to replace the transmission fluid or differential? I had two dealerships say they wouldn't do it period. This one said ok. I have a mix of opinions on the internet on "if it would help". I don't care about the cost as I'm owning this one for the long haul. Just the issue of risk... And thanks for the replies. |
09-06-2006, 11:22 AM | #7 |
Rep 69
I did an oil change at 1500 and a complete fluid change at 3000. Replacing fluids are never a bad thing ... "lifetime" is a very fluid term ... punn intended.
I change my diff and transmission with redline. I had to pump out the fluid of the diff since there is only a fill and no drain plug ... go figure that bright engineering feat. Total cost: around $100 |
09-06-2006, 12:32 PM | #8 |
Got Seoul?
116
Rep 2,862
Here is something that I lifted from the M3 boards. http://www.m3forum.net/m3forum/showt...t=fluid+change
[SIGPIC][/SIGPIC] |
09-06-2006, 12:34 PM | #9 |
Got Seoul?
116
Rep 2,862
This might help but not sure about the differences between the models. DIY fluid change. Seems to be the concensus that Royal Purple is the choice for fluid replacement over the BMW OEM. http://www.m3forum.net/m3forum/showt...t=fluid+change
[SIGPIC][/SIGPIC] |
09-06-2006, 02:54 PM | #11 |
Rep 69
my bigger concern was to get the engine oil changed within the first 1500 miles and the diff/trans in the first 3000 miles. At 1700, I would not hesitate to do all of them at once ... just want to remove any shavings ... check out august roundel, pg 122, guy did the same thing and found many shavings.
11-15-2011, 01:49 PM | #13 |
160
Rep 224
So I get that this is a very old thread, but I can't help myself in pointing this one out. So in order to get the old fluid out of the car, you're going to remove the entire diff from the car so you can tip it over and pour out the fluid?? Hmmm, or you could try a pump!
11 BMW E93 M3-- 06 BMW Z4M Roadster
99 BMW M Coupe -- 85 BMW M635CSI 97 M3 Coupe (Track)--95 BMW M3 Coupe 91 BMW 850i 6MT--20 Ram 1500 16 Chevy Tahoe 4WD |
11-15-2011, 02:49 PM | #14 | |
18
Rep 345
11-16-2011, 01:18 AM | #15 |
21
Rep 780
wow, a five year old thread revived from the dead...
Yes, they need to stand the car up on end to get the diff fluid out, they also need to flip the car over and bang on the underside a few times to make sure they get the last few drops out. Or I hear some shops get around this by using a fluid extractor |
