15" sub in an e91
08-11-2009, 03:08 PM | #1 |
Rep 12
15" sub in an e91
anyone ever done this .. i searched an i saw that everyone uses 10" or 12" .. and also i am using a monoblock amp that uses 120amps from the battery and i saw that with the block thing on the terminal on he battery the highest amperage on it is 50amps .. any suggestions?
08-11-2009, 06:03 PM | #2 |
289
Rep 3,201
I have an E91 and I would never use a 15" in the back! Too much space.
If you want to use huge amps, you need to upgrade your battery and use a different type of connection. |
08-11-2009, 08:03 PM | #4 |
75
Rep 1,009
Drives: 2007 JB/Saddle E92 335i
Bigger amp.
08-12-2009, 03:15 PM | #5 |
Guest
36
Rep 611
Get a better amp. I wouldn't suggest getting a 15'' since it hits too low. I think that a good 12'' is optimal.
2006 Black BMW 330i, Black interior, ZSP, ZPP, Logic 7, Xenon, Ipod, Satellite Radio Preparation, Moonroof, 12'' 2 P2 subwoofers running on KAC-7204 amplifier, Hardwired Escort Passport 8500, Hardwired Garmin Nuvi 650 on Kuda Mount.
tutor,math tutoring,math tutoring,test prep,tutoring jobs,tutoring blog |
08-12-2009, 08:04 PM | #6 |
Rep 12
the amp itself is 1200watts btw...a monoblock mb quart...but i wanted to know how i wud go about connecting it to the battery since the maximum allowed on the block thing on the battery is 50 amps..because the amp itself uses 120amps
08-13-2009, 04:21 AM | #7 |
394
Rep 3,161
i am running a pair of Arc Audio amps that pull much more juice than that. No worries there. I am also in the works of a dual 15" free air setup. Will only take up 9-11" of trunk space. Here is an example of how it was in my M5. www.tmrmzine.com/m5
