Fs Pes Tt 35
07-20-2009, 08:02 PM | #4 |
109
Rep 3,334
Hahaha I don't think I have heard of this piggyback either.
Mods list got too long, lets just say more than enough.
07-21-2009, 10:08 AM | #5 |
18
Rep 261
it a chip that pes came out with..
its run 406 hp and 467 tourque http://www.e90post.com/forums/showthread.php?t=152630 http://www.chip2perform.com/ |
07-24-2009, 11:01 AM | #8 |
Rep 332
If you go to there site there really no info no dyno on there website I dont know but it looks suspect. Its just a metal box with wires. If I was to buy a piggyback tune I would goto dragtimes and check what people are using. There is no track record for this product. Yes there are threads in this forum thats where the info is but its not from the manufacture. Before anyone decides to spend your hard earned dollars you should do more research. Look at the trend when a vendor wants to sell their products they have a factory rep offer groupbuys introducing their products so everyone will know about their products.
Just my 2 cents anyway. |
07-30-2009, 12:49 AM | #11 |
18
Rep 261
http://www.pes-tuning.com/
that the company site... they make files for the high end car. i got the chip from tuning technology.. guy name bruce... if you see his site ttmotorsport.com he one that build some of us record cars like the fastest m6. he the one that recommended the chip since it wouldn't cause error and disable safety features unlike the other piggyback even though it produce more power you putting the engine in danger and faster turbo or fuel pump failure. on the other note service wouldn't be able to tell and wouldn't give you trouble unless they open up the ecu. i personally thought the chip was amazing. it was night and day... since i had a XI model there was still so much power that if traction was off and you floor you are even able to burn out a little.. |
08-02-2009, 12:48 AM | #14 |
18
Rep 261
your car not gonna get mess up because it keep all the safety feature on. as for the warranty they can tell its on the car...
08-04-2009, 10:18 PM | #16 |
18
Rep 261
to not void the warranty you just need to pull out the chip.. since its only one pin it take less the 20 min to take out.. they wont be able to tell its on the car...
personally i went in to service about 3 times with the chip they didnt know about it... first was for oil change. second was for broken tail lights. third was for brake flush... every time i went in i had the chip in there... |
08-05-2009, 12:07 AM | #17 |
675
Rep 4,080
1 pin? And it gives you that much power? And won't throw a code with post 29.2 software, the same software that required both JB and Vishnu to create new maps with comprehensive fuel mapping in order to not throw codes?
Not to diss your post, but I don't see how that's possible. |
08-06-2009, 11:21 PM | #18 |
18
Rep 261
its one pin. but there two tubes that connect to the turbo air filter..
the black pieces that you see on the side of the engine near the ecu... 2 vacuum lines for the turbo boost solenoids |
08-07-2009, 06:09 AM | #19 | |
Joint Chiefs of Staff
4920
Rep 115,999
Mike |
