245/40ZR-18 BF Goodrich R-1
07-08-2009, 01:05 PM | #1 |
Rep 169
Can I get these to work some how with my stock 18's?? style 162 8" fronts 8.5" rears... Or using them on some Kosei K3 18x8.5 all around?? Is it bad to not have them staggered? I would be using this set up for track only. Any advice would be greatly appreciated. |
07-08-2009, 01:58 PM | #2 |
863
Rep 2,897
You should be fine, lots of people running that setup. Just be careful with offsets
You don't want anything lower than 32 at the front with 8.5 " rim Ideal offset is 35-37 Do a search for staggered and you will find plenty of info |
07-08-2009, 02:04 PM | #3 | |
Rep 169
Thanks for the response! I should be fine with either set up or the kosei setup? |
07-08-2009, 04:04 PM | #4 |
BimmerPost Supporting Vendor
2040
Rep 25,989
What are the offsets on the Kosei's? 245/40/18 all around is perfectly fine with the proper offset. +35 is an ideal fitment for a 8.5" wheel.
You'll like those R1's, iv heard they stick like glue when you heat them up. -Charles@VMRWheels
VMR|Wheels | 714.442.7916 |
07-08-2009, 05:09 PM | #5 | |
Rep 169
18x8.5 Offset: 30mm Backspacing: 5.90" Bolt Pattern: 5-120 Rec. Tire Size:225/40-18 Weight: 20.4lbs. So, I could use spacers to get the proper offset? And using the 245's front and rear would be a fine setup? I also have pss9's lowered about 1.5" in the front. |
07-08-2009, 07:07 PM | #6 |
2040
Rep 25,989
18x8.5 +30 all around with 245's are perfectly fine. I dont see why you should need any spacers.
-Charles@VMRWheels
07-09-2009, 02:35 PM | #8 | |
863
Rep 2,897
07-09-2009, 02:36 PM | #9 | |
863
Rep 2,897
You can run rears in the front with the 255-35 no problem. Or you can use the OEm's with same tire size all around although 245 on a 8' rim will be stretched |
07-09-2009, 03:00 PM | #11 |
Rep 169
07-10-2009, 01:57 PM | #12 |
15
Rep 701
Uh, tirerack has the Kozies in 40mm offset. That should work. 30mm is going to have the tire sticking too far out.
Why don't you just get teh 40mm offset?
_________________________________________________
07-10-2009, 02:35 PM | #13 |
Rep 169
