Run flats and disconnected from the road?
07-08-2009, 12:10 AM | #1 |
50
Rep 582
I was able to finally get my car up to 75-80 mph coming back down from work since I've gotten it couple of days ago and I don't know if its the run flats with the non sport wheels or what but the car feels very unstable or disconnected from the road when I'm going 80. It feels "floaty" when I'm at those speeds. I don't get that same feeling of being on the road as I did on my old TL. Would maybe changing the tires and bigger rims and maybe sway bars reduce this floaty feeling because although it's not that noticeable, it sorta makes me nervous to keep cruising at those speeds. Maybe its the run flats' sidewalls?
07-08-2009, 12:51 AM | #2 |
923
Rep 15,818
i feel very stable for speeds up to 110
havent really gone more than that in this car yet... in my merc, i had Pilot Sports and PS2s, not run-flats, but they were fine u to speeds of 140 easy. if you feel floaty that's not good... tires old? be careful... 75-80 isnt that much... |
07-08-2009, 12:56 AM | #3 |
50
Rep 582
It's brand new. Only has about 350 miles on it. This floaty feeling feels like the car isn't planted on the road. Like I'll be going straight on the freeway but the car will sway ever so slightly left or right occasionally ( maybe rocking is a better term? ) and I'm guessing harder/lower/sportier suspension would solve that but even for a stock car, it doesn't make me feel confident about driving it any faster.
07-08-2009, 12:58 AM | #4 |
Where'd my VTEC go?
481
Rep 6,067
have your alignment checked, somethings not right. hell, even my accord felt solid over 80mph.
07-08-2009, 01:00 AM | #5 |
50
Rep 582
I don't think it's my alignment. It's not like the car is pulling in a direction. The wheels are going straight, but the car itself which is ontop of the wheels feel floaty. =/ Not exactly sure how to explain it, prob have to experience it yourself to understand what I'm trying to say lol. I'm really hoping its the runflats because they have really large and solid sidewalls along with the stock suspension on regular non sport wheels which are I believe 17-16 inches?
07-08-2009, 01:16 AM | #6 |
BMW, can I have some LSD please?
88
Rep 1,591
Check your tire pressures.
They may be too high if someone had forgotten to lower them to the proper setting during the PDI process. It is intentionally set high at the factory for transportation purposes so that the tires do not develop flat spots while sitting in the ship/lot/etc.
2006 330i | TiAg | Black | Al | 6MT | Sports Package | Logic 7 retired
2008 335i | AW | Black | Al | 6MT | Sports Package | Logic 7 retired 2013 328xi | Red | Gray | Al | 8AT | Sports Line | Premium | Executive | Heat Pkg retired 2017 340i xDrive | Estoril | Black | Al | 8AT | M Package |
07-08-2009, 01:24 AM | #8 |
15
Rep 445
It may well be the alignment. I have RFTs and the car is planted to the road at any speeds. Have it checked.
Also, new tires need to be broken in. Give them ~500 miles; make sure they are properly inflated (I like mine being about 4-5 psi over the recommended numbers). One more thing - it could be the steering feedback that you may not have had in your previous car. |
07-08-2009, 01:28 AM | #9 |
Where'd my VTEC go?
481
Rep 6,067
Check the door jamb. There should be a tire pressure sticker.
Alignment can affect more than pulling to the side. Caster and toe can have an affect on high speed stability.
07-08-2009, 01:28 AM | #10 | |
88
Rep 1,591
Don't forget to check when the tires are cold, ie. not driven for a few hrs.
07-08-2009, 01:29 AM | #11 |
50
Rep 582
X-x wow ok so many variables so it may either be:
1. alignment 2. too much tire pressure 3. not enough tire pressure 4. steering feedback 5. not broken in 6. cold tires |
07-08-2009, 01:31 AM | #12 |
Where'd my VTEC go?
481
Rep 6,067
You might also be experiencing tramlining (the car's tendency to follow grooves and ruts in the road). I find the OEM Potenza RFTs tramline pretty badly.
But if its a constant feeling of unstability, then its probably not tramlining. Just take it to your dealer and go on a test drive with the SA to show what you mean. And see if they can fix it.
07-08-2009, 01:33 AM | #13 | |
88
Rep 1,591
Anyways, the easiest is to check your tire pressures first. I had exactly the same experience as yours when I picked up my new BMW a few yrs ago, floaty and all, and when I checked, the pressures were at 45psi!!!
07-08-2009, 01:33 AM | #14 | |
50
Rep 582
07-08-2009, 01:36 AM | #15 | |
88
Rep 1,591
And if he takes it to the dealer, I would bet dollars to donuts that they will test drive it and will say that it is within normal limits!
07-08-2009, 07:23 AM | #16 |
20
Rep 637
might be the car itself and downforce. i have the sport tires on my coupe and right around 70-80 it doesnt feel as solid as >80. it might have to do with the suspension tuning as well. the suspension i think is actually softer than the old 3 coupes to compensate for the rft harshness. as another poster said give the tires some time they may still have the mold release compound still on them. it takes a while for them to break in. but cant reaaly tell what youre experiencing without driving it. maybe go test drive another one and see if it feels the same.
07-08-2009, 10:38 AM | #17 |
Ski bum
317
Rep 6,198
Make sure the dealer pulled the blocks out of the springs. They put them there for shipping, I've seen where more than a few have forgotten to take them out.
1999 e46 328i Ti Silver / Black[retired] 2007 e90 335xi Jet Black / Black[retired] 2011 e70 X5 35d Vermillion Red / Cinnamon 2011 e92 M3 LeMans / Fox Red extended |
07-08-2009, 10:50 AM | #18 | |
Chief Warrant Officer 4
53
Rep 726
Drives: 335I, E46 M3, X5M
07-08-2009, 05:03 PM | #19 | |
6659
Rep 15,858
BTW, BMW did a full KDS, but it's not alignment, that made no difference to the unplanted feeling. HighlandPete |
07-08-2009, 11:35 PM | #20 |
88
Rep 1,591
So, sokdo, how were the tire pressures?
07-08-2009, 11:39 PM | #21 |
50
Rep 582
How do I check it? lol I was fidgeting with all the control on my commute to work this morning and I couldn't find the darn thing. ( Don't worry, the commute is like 5 mph with stop and go so I wasn't endangering anybody ) I need to find the owners manual somewhere in the garage unless a nice person tells me how to find it
07-08-2009, 11:53 PM | #22 | |
88
Rep 1,591
You'd have to get a tire pressure gauge: and stick into into the tire valve stem like this: If you've never done this before, you'll need someone to show you.
