E92 - 19*8.5 + 19*9.5 - Tire Size Question
07-06-2009, 07:06 AM | #1 |
Rep 88
Hello, i have an E92 running CSL reps 19" staggered, i am on 235/35 Front and 265/30 Rear at the moment but would like more side wall what tires could i go up to on stock suspension.
Thanks, n0s |
07-06-2009, 03:30 PM | #2 |
517
Rep 3,612
You could do a 255/35/19 in the rear to give you some extra tire height, or depending on the tire brand, and as long as your rear wheel offset is 30 or higher, you could run a 265/35/19 rear tire
07-06-2009, 04:20 PM | #3 |
BimmerPost Supporting Vendor
2040
Rep 25,989
^^ Sidewall height would be about 10mm taller then the 265's if you decide to run 255/35/19.
-Charles@VMRWheels
VMR|Wheels | 714.442.7916 |
07-06-2009, 07:11 PM | #4 |
43
Rep 1,071
07-06-2009, 10:55 PM | #5 |
Rep 244
225/35 or a 235/35 in the front if you were to match it with the 255/35/19. Proper tire size would be the 255/30, although not every company makes a 30 profile 255 in a 19".
You might know me from E46Fanatics.com |
07-07-2009, 02:42 AM | #6 |
Rep 88
Thanks guys,
So lets say i go with 255/35 or 265/35 for my rears that gives me an extra 10-13mm height which is good, what fronts do i go for to get some extra height over the 235/35 i have at the moment. Last edited by n0s; 07-07-2009 at 04:37 AM.. |
07-07-2009, 10:30 AM | #7 |
Rep 244
235/40
07-07-2009, 02:16 PM | #8 |
2040
Rep 25,989
If your car is low, you might want to watch out for rubbing issues with the 265/35.
-Charles@VMRWheels
07-08-2009, 02:59 AM | #9 | |
Rep 88
235/40 Front - Sidewall Height: 93.98 mm 265/35 Rear - Sidewall Height: 92.71 mm What you reckon guys, will this work? Thanks, n0s |
07-20-2009, 10:48 PM | #10 |
Rep 25
Would the 255/35/19 work on 9.5'' rim? The OEM 19s are 255/30 on 9''.
335i E92 / Alpine White / Coral Red / Aluminum / MT / Sport / Premium / Nav /
07-21-2009, 12:33 AM | #11 |
35
Rep 753
I'm running 275/30/19 on sport suspension. A little more sidewall and no rubbing issues at all. If you feel you need that much more sidewall maybe you should move to 18's?
07-21-2009, 10:39 AM | #13 |
163
Rep 1,588
I'm running 235/35/19 on fronts and 265/30/19 on rear. Rim width is 8.5 front and 9.5 rear. Offset is 32mm. I have KWv2 coilovers. No rubbing.
