V710 LCI offset question
06-29-2009, 02:50 PM | #1 |
15
Rep 279
I know that the 19 x 9.5 +33 for the V710 is out. Would a 19 x 8.5 +25 FR and 19 x 9.5 + 33 would look okay in a lowered H&R sport E90 LCI?? I am open to fender rolling...I want the flush aggressive look but my 3 kids always tag along in the car so I frequently have 3 passengers at the back...
V710 gurus (Long, Charles, etc??) please advise....thanks much!!! From LA here!! Thanks!!
Eurorev.com
06-29-2009, 02:52 PM | #2 |
173
Rep 6,223
no it won't work for the front, your front setup is too aggressive right now!!
2006 E90 Alpine White 330i - Retired
2015 F80 Alpine White M3 |
06-29-2009, 04:22 PM | #5 |
173
Rep 6,223
yes that will fit, but i m not sure about the spacer for the rear!
06-29-2009, 04:54 PM | #6 |
Perf BMW mag issue 147, 159
414
Rep 6,803
Im running 19x8.5 +25 up front with a 235/35/19 tire and its fine.... I get minimal rubbing on certain turns with bumps but nothing crazy.... And it's slammed
'13 Estoril Blue 335i M-sport
*Don't PM me!* Message me here- http://www.facebook.com/ProjectEstoril |
06-29-2009, 04:58 PM | #7 |
15
Rep 279
thanks for the response clean335...I've always admired your car...you are running 19 x 10s 38 offset right now correct??
Have you had any experience on a 19x9.5 22 offset LCI?? I was thinking to get the 19 x 8.5 25 offset in the front and 19 x 9.5 33 offset rear with probably 5mm spacer...do you think it would work with an HR sport drop?? thanks!
Eurorev.com
06-29-2009, 05:03 PM | #8 |
62
Rep 1,211
06-29-2009, 05:40 PM | #10 | |
414
Rep 6,803
My current rear set-up is 19x10 +33. It's a +38 wheel with a 5mm spacer. I've posted in several threads recently with people questioning the 19x9.5 +22 set-up on the LCI. I was running this on my '07 E90 and swapped it on the LCI when it finally arrived. Sure enough, it rubbed. Even at stock height. I figured if it was going to rub even before I lower the car, it wasnt even worth my time to do fender work. So I went with the 19x10's No rubbing in the rear even with the spacer. And its just as low as the front
06-29-2009, 06:15 PM | #11 | |
BimmerPost Supporting Vendor
2040
Rep 25,989
-Charles@VMRWheels
VMR|Wheels | 714.442.7916 |
06-29-2009, 06:22 PM | #12 |
257
Rep 4,048
Here's a picture of an LCI with M3 offsets in the back (not the front) - ET22 on 9.5" just for reference. You can go pretty aggressive in the back, but you will get rubbing issues.
Sticking with the ET33 should be just fine |
06-29-2009, 06:28 PM | #13 |
15
Rep 279
that flushness my friend is exactly what I wanted....i have the same exact car...I don't know if a 33 offset would be as flushed as that...
I don't mind rolling the fenders bydway... thanks...
Eurorev.com
06-29-2009, 06:32 PM | #14 |
257
Rep 4,048
06-29-2009, 08:23 PM | #16 |
414
Rep 6,803
My rear now.......
My rear before.....
06-29-2009, 08:24 PM | #17 |
414
Rep 6,803
couldnt have done it without your help
06-29-2009, 08:31 PM | #18 |
Where my bitches
743
Rep 1,924
Drives: Cadillac coupe deville
im about to run vmr v714 19x8 +38, 19x9 +38 with 5mm spacers on a 07 e90 just wanting to make sure it will fit properly
06-29-2009, 09:22 PM | #21 |
414
Rep 6,803
That was the 19x9.5 +22 same tire as the one on the 19x10 now.
