Run flat tires and wheels?
06-29-2009, 02:03 AM | #1 |
18
Rep 53
Is it true that only Run flat tires can be mounted on 2006 BMW 325i (with sports package) wheels?
Currently I have run flat tires on the vehicle. Do I need to change the wheels if I want to use Non Run flat tires? Please clarify. Thanks in advance. |
06-29-2009, 03:11 AM | #2 |
Where'd my VTEC go?
481
Rep 6,067
there is nothing special about the wheels for regular RFTs. you can mount non-RFTs on them, but keep in mind you dont have a spare or jack if you get a flat.
the only special kind of runflat sold today is the Michelin PAX system.
06-29-2009, 03:17 AM | #4 |
17
Rep 230
Yes they can. I have the 161 style wheels and just recently put on Vredesetin Ultrac Sessantas on, and they fit without any issue.
I believe the problem arises if you are trying to fit a RFT on a standard wheel, or if you are using Michelin (or Goodyear's?) special RFT solution with the internal doughnut, where the rim is radically different. |
06-29-2009, 05:09 AM | #5 |
205
Rep 3,523
Drives: 2015 F23 M235i/2008,E90,335xi
buy a spare for a E60 f/ Tisher, it comes w/ a jack, etc.
it fits perfect w/ your E9x. your ride will greatly improve w/ non RFT. |
06-29-2009, 11:22 AM | #6 |
18
Rep 53
Thank you very much for all your opinions.
I was told by the dealer that I need to change my wheels if I want to go with non run flat tires since the wheels on the vehicle can fit only RFTs. So I guess he was wrong. |
06-29-2009, 11:35 AM | #7 |
18
Rep 53
