The Tire Rack
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > AUDIO/VIDEO + BLUETOOTH + Electronics/Alarm/Software > Upgrade air con to climate control panel?
      06-27-2009, 10:37 AM   #1
adfhklkhkjrenwrw
10
Drives: ffhadsjkfhkldnj
Has anyone here successfully retrofitted the automatic climate control panel to a "manual" air con BMW e90?
I bought an auto climate control panel on ebay for £15, is it really as easy as swapping over the panels, "plug and play"?
I accept that I won't have full "dual climate control", which I don't really need - all I am after is the cosmetic improvement of the digital panel over the manual air con controls.
If anyone could tell me whether a) this will work, and b) whether the auto module will be able to control my "manual" air con - particularly which functions will/won't work, I would be *extremely* grateful.
Thanks,
Matt
      06-27-2009, 10:56 AM   #2
F104
Belgium
19
Drives: E92 320D M-sport
If that works i'll park mine between a E90M3 and E93M3 and hope to get at least a335i with sunroof
      06-27-2009, 12:05 PM   #3
adfhklkhkjrenwrw
10
Thanks - helpful!!
      10-29-2009, 05:48 PM   #4
laihon
Drives: bmw 323i
hey i have the same question. not sure if you tried to switch the panel yet. if it worked or didnt, can u let me know. thanks
      11-06-2009, 02:49 PM   #5
msitter
Drives: 2007 328i Convertible
We had that same discussion on LS1GTO as the Holden comes with an electronic HVAC and the GTO came with a manual setup. It was determined that a whole bunch of parts in the system are specific to the type of controls and is not simply plug n play. Air door controls, temperature sensors to name a few are completely different. I would suspect that it is the same with the BMW.
      11-14-2009, 02:57 PM   #6
Vasil
Vasil's Avatar
Drives: M3, M5 and 330i
Such a swap was not easy on the e36, so it most likely won't work without additional effort on the more complicated e90.
