BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > AUDIO/VIDEO + BLUETOOTH + Electronics/Alarm/Software > Phone Docking Cradle Installation
      07-28-2005, 03:29 PM   #1
David
Guest
n/a
Drives:
I drive an '06 E90 with Navigation & Bluetooth installed. I have the system base plate part # 84-21-6-946-075 and the adapter #84 21 0 307 726. Does anyone know where I can get an installation guide? Classic BMW in Dallas, TX referred me to an installation specialist that can't seem to figure it out...it has been a month. The installer says "it appears that we need additional parts"... Thanks, David.
      07-29-2005, 04:01 AM   #2
Broken1
Addict
Broken1's Avatar
203
Drives: 2024 X5 40i M-Sport
I've got the bluetooth installed aswell. I've got a "blank" cradle over the place where it is...
If you push the button (circled inred below) remove the blank cradle, the cradle from BMW should just snap in it's place!
I hope this helps...
      01-21-2006, 01:16 PM   #3
TrackJunkie
TrackJunkie's Avatar
Drives: Interlagos Blue '13 M3 Coupe
2013 BMW e92 M3  [0.00]
2006 330i  [0.00]
My E90 330i Mfg. 10/05 does not have that kind of button. I only have a rubber cover in this center console, so do I have to pull something else apart?
Interlagos Blue 20134 M3 Coupe, Comp Pkg, DTC, iDrive, No other options to keep it light
View My Garage -
http://www.e90post.com/forums/e90gar...garage&id=7562
      02-04-2008, 07:14 PM   #4
Drive3
Drives: 2006 330i
yes you do have to remove the ruber piece.
you may also not have the (3) additonal wires in the back on the drives side under the carpet cover over the wheel, the seems to be missing from the 10/05 producton, my car was produced in the same month. FYI the button in read is apart of the eject box.
I did the install also, very quick install. no need to remove the entire console, the required wires can be reached by unsnaping the leather shift boot.
you will have access from the drivers side, for the two connection cables.
      02-09-2008, 05:20 PM   #5
SoYank
SoYank's Avatar
571
Drives: 2009 E90 335i MT
The instructions are in P/N 01 29 0 403 645. My scanner isn't working right now so I'm going to enter all of the steps here for E90/E91.
Parts information:
  1. Console Trim, P/N 51 16 7 118 054
  2. Eject Box, P/N 84 21 6 946 075
  3. Snap in Adapter, this is phone specific with different part number for each.
Installation:
  1. Disconnect battery prior to beginning installation
  2. Remove emergency brake boot
  3. Verify that eject box is P/N 84 21 6 946 075 and is marked with "TCU" lettering underneath coin tray and FAKRA antenna connector has a yellow band near connector. Note: eject box has a pair of cables with connectors, one large and flat, the other is the FAKRA connector.
    Note: Correct eject box P/N 84 21 6 946 075 must be used to ensure proper functionality of snap-in adapters.
  4. Snap eject box into console trim piece 51 15 7 118 054, routing wiring through hole in trim piece
  5. Snap eject box and trim piece into center console. Route wiring from eject box [as shown]: cable through hole towards the front of the car and out through the emergency brake handle.
  6. Connect plug X4545 (large connector) to the plug and antenna plug X13322 on the plug for the eject box. These are underneath the console through the Emergency Brake hole and are held on with a plug connector holder. This holder can be seen and can be removed for ease of assembly.
  7. Clip the plug connectors into the plug connector holder
  8. Slide the plug connector holder into the odments box.
    Steps 9-12 are only for E90 vehicles produced from 03/05-04/05:
  9. Remove left side trunk liner
  10. Locate wire bundle near left side wheel arch.
  11. Unwrap bundle. This reveals three cables. Two are coaxial.
  12. Locate coax cables. If cables are not connected together, connect them. It may be necessary to remove a grounding cap from one of the connector halves. Note: multi-pin connector is not used in this installation.
  13. Reconnect battery
No retrofit coding is required for this installation.
Broken1, the blank cradle you describe is the coin tray mentioned in step 3 above.
TrackJunkie, if you have the rubber tray you don't have the cradle/eject box and will need to do the above steps. The adapter costs about $130. The eject box and trim are probably another $150, judging from my invoice which is in Pounds Sterling.
2009 E90 335i Montego Blue · Black Leather · Burl Walnut · 6MT · US Spec
SatNav • ZPP • ZCW • 6FL • TPMS • iDrive • PDC • HWS • Xenons • BMW Assist • Power Rear Sunshade • Logic 7
European Taillights • Rear Foglamp • OEM Alarm • PicoTray • DataToys XM-DVR • Multi-view Processor
Quaife ATB LSD • Short Shift Knob • Hartge Anti-Roll Bars • AP Racing Front Brakes • 19" Style 269
