E90 LCI 335i M-Sport tyre pressures
06-20-2009, 04:27 PM | #1 |
230
Rep 3,899
Hi,
My LCI E90 335i M Sports steering feels very light at speed and the car tends to 'bounce' over small bumps in the road resulting in the car not feeling planted on the road. Im convinced its the tyre pressures. Im on michellin Front= 225/40ZR18 88Y and Rear255/35ZR18 90Y. The sticker inside my door says 2.3Bar (33.5PSI) front and 2.7Bar (39PSI) rear. Ive played around with the pressures and have found a huge difference in steering feel and the 'bounce' issue depending on what pressures im running. The upshot is that 2.3/2.7 just doesnt feel right. Anyone with the same tyres on M Sport suspension who could advise on what theyre running on their car would be greatly appreciated. What does the manual in the US recommend for these tyres on M Sport?? Also any tyre experts who could offer some pros and cons of different pressures on RFT- your advise would be welcome. Thanks. |
06-20-2009, 04:39 PM | #2 | |
114
Rep 1,148
Drives: 09 E92
09 - 335i E92 / Monaco Blue
06-20-2009, 05:00 PM | #3 |
230
Rep 3,899
Are those pressures with M Sport suspension? If so i wonder why theyre different to UK spec cars???
06-20-2009, 05:03 PM | #4 |
313
Rep 3,262
I use 2.5 bar on front and 3 bar on rear (the recommended pressure) on my 335i e90 LCI M Sport, but I have 17" wheels (225 on front and 255 back). The car is running fine.
06-20-2009, 08:12 PM | #6 |
339
Rep 820
Our Sport and M Sport suspensions are the same in the North American Market. Our recommended sport package 18" diameter pressures are 33 front and 41 rear (for speeds up to 100mph). These are the pressures listed on the door and in the manual.
I'm running Michelin run-flats on mine that are set to factory pressure and the ride is great. Excellent even. Compared to my Bridgestones on my old 2007 335, these are AS GOOD as non run flats! Last edited by Raikkonen; 06-20-2009 at 08:19 PM.. Reason: left out info. |
06-20-2009, 09:00 PM | #7 |
13
Rep 508
my fatty 325xi still jumps over the gutters on bridges, it freaks me out. I think its just the fact that the car isn't 3 tons like my old truck, though.
E90 328i Space Gray/Chestnut ZMP 2MF ZP2 ZV2 ZCV ZCW-washers HK SAT 3rd Pedal ED 2011.10.10 E90 325xi BSM/Terra ZSP ZPP ZCW Adaptive Xenons SAT 3rd pedal Gone E53 X5 3.0i Black Sapphire/Truffle ZPP ZCW ZRC Xenon Nav |
06-21-2009, 08:09 AM | #8 | |
230
Rep 3,899
06-21-2009, 08:51 AM | #9 |
90
Rep 2,707
Keep in mind BMW's recommended number aren't necessarily the best ones for YOU. They are the best settings for the AVERAGE driver.
I would a) Keep the pressure the same around the 4 corners to achieve maximum balance for the car. b) Play around with the setting until you find a good compromise. Anything below 32-33 you start adding the risk of getting your rims bent. In terms of actual performance (not comfort) you can use one of those laser thermometers and measure the heat level across the tire after a long highway drive. The idea is that the middle of the tire has to be in the middle of the inner and outer sides (temperature).
zhpregistry.net - ZHP stats and free classifieds.
06-21-2009, 06:32 PM | #10 |
339
Rep 820
According to my owners manual:
Over 100 mph for the 335 w/ factory sport package, 1 driver + 3 passengers maximum, and 18 inch rims: W rated tire (speeds up to 167 mph) F - 36 psi R - 41 psi Y rated tire (speeds up to 186 mph) F - 32 psi R - 36 psi |
