big wheels = no drop?
06-19-2009, 02:24 PM | #1 |
19
Rep 169
Hey everyone,
First of all, I don't know much about wheels and tires so don't hate and please explain things for me So I'm thinking about getting a new set of wheels and tires, moving away from the runflats that I have on my style 162 wheels. Right now I have 18" wheels and factory suspension. If I were to get 19" or even 20" wheels would it make it less necessary to get a drop? Also, If I go for a bigger wheel diameter do I need to do anything special to avoid rubbing or anything? Sorry for so many questions but can I go the cheap route and put regular tires on my rims which have rfts right now? Thanks, Leopard EDIT: I have 08 E90 if that makes any difference |
06-19-2009, 02:28 PM | #2 |
Rep 244
No a drop isn't NECESSARY, but it does make the car look much better. The optical illusion makes the car to appear raised (even with proper wheel/tire sizing to maintain the same overall rolling diameter).
The diameter isn't really the problem as long as you have proper tire sizing. It's the OFFSET that can cause you to rub the inside of the fenders either at full-lock or under compression. I'm assuming you're going with a staggered setup with most likely an 8.5" 35mm front and a 9.5" rear with a 30mm or a 10" rear with 30mm. Also rolling the rear fenders will yield an additional 5mm of clearance if you were looking to run some more aggressive offsets or are looking to lower the car aggressively. When I finally upgrade to an E90 with new wheels I will for sure be ditching those atrocious runflats for something better like some Nitto NT-05s or Dunlop Direzza Z1s.
You might know me from E46Fanatics.com |
06-19-2009, 05:39 PM | #3 |
361
Rep 5,859
Drives: Vorsteiner E60 M5
Location: 1460 White Oaks Rd. Suite F. Campbell, CA 95008
Generally when you get new wheels you try to maintain the same diameter of the tire by cutting into the tire space.... so... it won't solve your drop problem too much, maybe a little.... I guess optical illusion will help.... But I'm on 20's, and slammed, and loving it
06-19-2009, 08:06 PM | #5 |
19
Rep 169
Thanks for the replies I appreciate it.
Any opinions on just putting regular tires on the 162 rims I have after taking off the rfts, is this a decent alternative? |
06-20-2009, 12:42 PM | #6 |
Rep 244
Yes that's a good option as well.
