19" tire suggestions for my xi
06-19-2009, 02:14 PM | #1 |
28
Rep 166
Wondering what size tires I should be buying for my XI. It's my first AWD car and the wheels are staggered so I want to be sure on the correct tire sizes before I make my purchase.
The wheels are OEM 225M's: 19x8 ET35 19x9 ET39 Thanks |
06-19-2009, 06:44 PM | #2 |
BimmerPost Supporting Vendor
2040
Rep 25,989
235/35/19 and 265/30/19 works perfectly fine with your setup.
-Charles@VMRWheels
VMR|Wheels | 714.442.7916 |
06-20-2009, 12:24 AM | #4 |
Wang D.D.S.
185
Rep 7,057
Tischer BMW....
06-20-2009, 09:57 AM | #6 |
1618
Rep 2,161
I think the OEM 19x8/9" wide staggered tires are 225/255 respectively. How different is the look of 235/265? Is there any advantage to either size?
06-20-2009, 10:04 AM | #7 |
633
Rep 24,685
Drives: '04 330i ZHP
wider looks better... not much advantage in an AWD for the larger/staggered set up, however I'm running 245f/275r with a drop and I have no rubbing issues at all.
Take a look at the Yokohama S.Drives if you're looking for summers. I just got mine last month and they are AMAZING. Sticky as glue on dry pavement and they do AWESOME in the rain (proved that yesterday durning the monsoon we go here going 60 on the highway while most cars were pulling over because of the down pouring). |
06-20-2009, 12:18 PM | #8 | ||
28
Rep 166
This is what I'm curious about. I also think BMW's suggested tire sizing for the 225M's is 225F/255R but don't know if I should be going up a size respectively for the x-drive - to maintain the proper rolling diameter or any other advantage??? |
06-20-2009, 12:26 PM | #9 |
G.O.A.T.!
1000
Rep 74,998
06-21-2009, 02:21 PM | #11 |
633
Rep 24,685
looks... if you want to maintain proper ratios you'd go same size all around. as long as you keep it 235/265 or 225/255 or even 245/275 (the ratio is less than 1% difference or something like that) you'll be fine.
06-21-2009, 02:38 PM | #12 | |
General
517
Rep 18,858
Do not do it. I have 235/265 on OEM 230's, and Iw ould not go wider on OEM rims. Aftermarket rims that are 9.5+ width can go 275 rear. |
06-21-2009, 06:09 PM | #13 |
379
Rep 11,992
Drives: M3 (e92), X5 (E70), 428i (F32)
Since you are running an 8" rim in the front you can also go with a 225.35.19 in the front with a 265.30.19 in the rear.
This would be better for your Xi than the 235/265 setup due to the closer overall diameter between the front and the rear. It's not a HUGE difference and either size would work, but the 225/265 setup would be a better long term size to run as the difference in height between the front and rear tire is less with that setup Zoeb |
06-21-2009, 07:03 PM | #14 |
633
Rep 24,685
