Tirerack
The Tire Rack
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > Wheels and Tires Forum Sponsored by The Tire Rack > 18" Style 189 work with a 335i? Maybe staggered?
      06-18-2009, 08:53 AM   #1
Joeb427
BMW CCA Member #420698
Joeb427's Avatar
17
Drives: '09 335i
Presently have 17"s and am thinking about going to 18" 5 spoke 189's with a 225/40-18's all around.
Could I stagger if I wanted to or would that void warranty?
      06-18-2009, 09:18 AM   #2
MSPORTWORLD
MSPORTWORLD's Avatar
232
Drives: '11 M3 MW/FR - '12 M3 FO/SC
189 wheels are 18"X8 (Fronts) and 18"X8.5 (Rears)
You should probably stagger them stock uses 225 F and 255 R but you technically can run 245s on all 4 corners if you want but you still can't rotate them 8.5's to the front so why bother.
Just stagger the tire sizes. Recommend 235/265
      06-18-2009, 09:24 AM   #3
Joeb427
Joeb427's Avatar
17
Drives: '09 335i
Thanks for the quick reply because I'm about to order the wheels and some Conti 18" SSR runflats from Tire Rack..
Can I just buy 4 18X8 style 189 wheels?
I'll probably just do 225/40-18's all around.This way I can rotate.
The 189 wheels should fit I would think.
      06-18-2009, 09:27 AM   #4
noro
noro's Avatar
Armenia
90
Drives: '91 M3, '04 E46 ZHP, '72 2002
It depends what you want to do with the car. Technically speaking, in a hands of a skillful driver a 225 all around setup is better. It will result in a much more balanced car in corners but will induce overstreer so it will be easier to get in trouble with it.
In terms of warranty I highly doubt they will have major objections to any tire choise..
zhpregistry.net - ZHP stats and free classifieds.
      06-18-2009, 09:53 AM   #5
Joeb427
Joeb427's Avatar
17
Drives: '09 335i
I play a little but think the same size tire all around will work for me.
Unfortunately,i just found out that Continental makes a 18" ContiProContact SSR RF tire but doesn't import the tire here.
Seems 18" RF are summer tires and won't work for me.I don't want to go with regular tires and have to buy a 5th tire and jack kit.
Maybe I'll just gut a set of Style 284 wheels and keep the 17"s.
      06-18-2009, 06:13 PM   #6
jopa489
122
Drives: Anything with Wheels
Either setup will work fine, you're talking OEM rims here. That makes everything much easier. My car had 17" 225s all around stock, but my summer setup (style 162, pictured below) is 18" and staggered 255/225.
Since you're in NJ, just put the stock wheels and tires back on for the winter and get summer tires. If you do end up moving away from RFTs, the Michelin PS2 is a great tire.
X7 LCI // Incoming
C7 ZR1 ZTK // Sebring + TRX // Hydro + Raptor Gen1 Roush // Tuxedo
      06-18-2009, 08:31 PM   #7
Proper Motion LLC
Custom Powder Coater
Proper Motion LLC's Avatar
147
Drives: White 335i Sedan
Y not just buy from our classifieds section. 189s with tires are always for sale there..
      06-18-2009, 09:38 PM   #8
Joeb427
Joeb427's Avatar
17
Drives: '09 335i
jopa,I really don't want to do a changeover.
The 335i doesn't see rain now and definitely won't see snow.
Summer tires lose traction,braking and wear fast in cold weather so I won't buy them.
If I go with 18" rims,'ll probably buy a set of Michelin Pilot Sport A/S Plus which are not run flats and the BMW spare kit..
      06-18-2009, 09:38 PM   #9
Joeb427
Joeb427's Avatar
17
Drives: '09 335i
Thanks Alpine but I haven't see any for sale without tires.
      06-18-2009, 10:41 PM   #10
tintivilus
tintivilus's Avatar
26
Drives: E92 335i
2007 E92 335i  [0.00]
2003 325i  [0.00]
Unless you're really tight with your dealer, I'd expect takeoffs with mystery rubber would be cheaper than new alloys.
      06-19-2009, 06:16 AM   #11
Joeb427
Joeb427's Avatar
17
Drives: '09 335i
Takes offs are great if seller is close.
I don't want another set of Run flats.I may dump the ones I have for a set of Michelin Pilot Sport A/S Plus.
I'm leaning toward style 287 but do like the 193 M wheels but they're pricey.
      07-08-2009, 06:49 PM   #12
tomob63
tomob63's Avatar
31
Drives: 2015 335i
have you made a buy? if so what direction did you go?
I have 189's on my e90 with 225 Front and 255 Rear.
They are runflat Bridgestones and I NEED to dump 'em.
Was thinking of going 245 all around, but not sure what brand of non-runflat tire.
