06-16-2009, 12:39 PM | #1 |
12
Rep 111
Bolt-on Rollcage for E92 M3 - Anyone?
Hello,
Does anyone in this forum heard of a bolt-on rollcage for a E92 M3? I've seen this kind of cage in many E46 but none on in our car. Its an option that I may consider for the end of the season or next year in order to install a 6 point harness in my car when tracking the car with a race seat. Thanks, Vince |
06-16-2009, 01:14 PM | #2 |
374
Rep 8,033
I considered this some time ago and concluded that it is a bad idea. There seems to be no point in "bolting on" a roll cage without welding plates to the chassis to reinforce the bolt locations. Otherwise, if you really roll the car (not a soft roll), the tubes will most likely go through the chassis or deform it significantly , and the "cage" will not function as a "roll" cage. Since your harness would be attached to it, you might be pulled along as well. One can argue that one can find bolt-on locations in the chassis that are strong enough, but I have a hard time buying that unless I see evidence/validation (in the form of a proper FEA sim or a real-world test) and would not take someone's "opinion" as proof--regardless of who he is. I saw an E46 a few months ago at the track with such a setup, and when I asked the owner why he thought it was safe, he said it bolts to where the seatbelts are attached in the chassis. He clearly had not thought it through because the max load a seatbelt can experience in a roll-over is obviously much smaller than what a roll cage would. Anyway, if what you are after is a harness bar, why not have an harness bar installed instead of a roll cage that won't really function without some serious welding/chassis modification?
06-16-2009, 02:26 PM | #3 |
142
Rep 3,522
+1 Lucid.
Roll cage is thre to protect the occupant and the only real roll cage is a custome mage weld-in style. Speaking of cages, check out this one on Rogues site. So killer. |
06-16-2009, 02:27 PM | #4 |
814
Rep 7,888
John from Raven Performance just built an E92 M3 for track days for a customer that has an extremly nice chrome-moly cage in it.A friends wife has a bolt in harness bar & roll bar in her E46 M3 that was also done by John.He also did a custom seat mount to install a proper race seat in her E46.This is a very good idea as you can run a Hans with no comprimise on the belt mounting.If there a lot of track days in the E92 in the future,I will probally go this direction.
http://www.ravenperformance.com/chassis http://www.ravenperformance.com/ |
06-16-2009, 02:35 PM | #5 |
814
Rep 7,888
06-16-2009, 06:26 PM | #6 |
609
Rep 10,407
I recall discussing this with you by PM. We certainly can not say a bolt in roll cage WILL function "perfectly" as designed/as intended, however it is also premature and unfounded to say that it IS a bad idea and WON'T function. I suspect that a properly designed bolt in roll cage on a street car will offer substantially improved protection under most crushing/compression types of loads. Shear loads might be a case where things could get ugly if the cage completely sheared from the vehicle. However, even under shearing you would likely get more protection with than without. I absolutely agree that FEA could answer the question quite well. However, careful considerations of the various load cases would be a key part of such an analysis.
E92 M3 | Space Gray on Fox Red | M-DCT | CF Roof | RAC RG63 Wheels | Brembo 380mm BBK | | Vorsteiner Ti Exhaust | Matte Black Grilles/Side Gills/Rear Emblem/Mirrors | | Alekshop Back up Camera | GP Thunders | BMW Aluminum Pedals | Elite Angels | | XPEL Full Front Wrap | Hardwired V1 | Interior Xenon Light Kit | |
06-16-2009, 06:56 PM | #7 | |
374
Rep 8,033
You can bolt various things into the cabin, and sure, they can increase the structural integrity of the cabin even if they are bound to fail. That's not the bottom line though. You will be strapped to the cage. If the cage deflects significantly, it will pull you along with it, and you can be crushed against your seat, against the cage, etc. I wouldn't want to be strapped/stuck to a structural element that has sheared off from its attachment point, and is continuing to deform under some kind of load. And if you were to quote/consider my entire post, what I mean by the cage "really functioning"--the language I used--would become clearer as opposed to it functioning in an uncertain manner.
06-17-2009, 12:10 PM | #8 |
12
Rep 111
Excellent feedback guys. Until someone demonstrate that this is safer then without one, I won't consider it. What surprise me is that Raven told me that they could make one for my car and that they didn't believe it would be so different than what I saw in a E46 in the same car as Gearhead999s mentionned above.
06-17-2009, 01:15 PM | #9 | |
374
Rep 8,033
06-17-2009, 02:45 PM | #10 | |
814
Rep 7,888
For the occasional trackday the harness bar setup is probally not a bad way to go as it at least allows you to use a proper harness setup with a Hans device,but contributes nothing to helping to save the Tub in case of a major incident.I know my car will turn times in street trim at Mosport that would have qualified mid pack in a mid 70's Trans Am race.That is real quick a car with only street safety gear!Just something to think about. Last edited by Gearhead999s; 06-17-2009 at 03:01 PM.. |
06-17-2009, 03:15 PM | #11 | |
30
Rep 915
vz
Previous Track Toy |
06-17-2009, 03:22 PM | #12 |
814
Rep 7,888
06-17-2009, 03:44 PM | #13 | |
374
Rep 8,033
Speaking of protection, I did order an R3 device last week. Hoping to start using it this weekend. Also hoping not to be in a position to write a product review for it.
06-17-2009, 03:59 PM | #14 |
814
Rep 7,888
Now that I remember we had problems with tech as we also had used the seat belt mounts to locate the main hoop which was bolted through and used much larger mounting feet than allowed by the rules.Once the cage was welded into that car it had a couple of huge hits that would have destroyed the car when the cage was a bolt in.
06-17-2009, 06:42 PM | #15 |
12
Rep 111
What are you talking about exactly when you refer to "harness bar setup"?
Is this an option that can be added to a car without any modifications? Tell me more please. Thanks again, |
06-17-2009, 08:04 PM | #16 | |
814
Rep 7,888
http://www.ravenperformance.com/rollbars-2 |
06-18-2009, 03:35 PM | #17 | |
609
Rep 10,407
Personally I would not put such an item into my car simply because I won't be tracking often and it moves the car too far away from a full street vehicle. It is a pretty major and irreversible modification (holes in carpet, trim, etc.). However, I just do not think it is fair nor accurate to say that because the system is not fully known/quantified/guaranteed then it IS a bad idea. I can appreciate the conservative point of view and agree that unknowns are bad. However, I'd place a strong bet that under virtually any roll over event no matter how the roll cage was mounted, you would be better off with it than without it. Of course with the very reasonable assumption that the cage itself is plenty strong enough. There are plenty of unknowns in a roll over without a cage as well, that doesn't mean you should never track nor drive your car on the street does it? By the way, I thought my partial quoting accurately represented your opinion. I did not do it to misrepresent you.
06-18-2009, 11:46 PM | #18 | |
374
Rep 8,033
An interesting comparison would be to consider full on welded safety cages. I wonder what type of analysis those are based on? I must assume there is some of analysis. But more importantly, my guess is that people have simply learned a great deal from trial and error engineering in those cases. A race car rolling over in a race is not such an unlikely event whereas an enthusiast with a bolt-on partial cage rolling over in a HPDE is pretty rare.
06-19-2009, 07:14 AM | #19 | |
814
Rep 7,888
06-19-2009, 07:06 PM | #20 | |
15
Rep 89
I think having welded plates isn't a bad idea when using a bolt-in bar, as I have seen where in a rollover the main hoop did push through the floor of a vehicle, but I don't think not having them makes you any less safe than you would be without any sort of rollbar. I'd still take a bolted in (only) roll bar over no roll bar any day of the week. A roll bar isn't only going to help you in a rollover situation, either. A side impact, depending on where you are hit, and a rear impact (also depending on where you are hit) are both incidents that can and do happen at the track. Having the additional protection at the 'B' pillar, and between the rear shock towers/rear seats, is certainly something that can be beneficial. I also think that even if the main hoop feet push through the floorboards, you're still deflecting more energy than you would have without a bar. In that, I'll agree with swamp2 that it's better than nothing. I've seen a couple roll overs with bolt-in bars, and more didn't push through the floor compared to those that did. A harness bar, in my opinion, is not a solution, and I wouldn't use one personally. Sure, it helps you with getting a set of harnesses to sit properly compared to the clip-in style Schroths that angle downward, but let's think about it for a minute. If you roll your car without a roll bar, the roof is at risk of coming down and smooshing your head. With a three point harness, if your head is getting pushed down, your body can 'lean' in towards the side of your body without the shoulder belt, maybe giving you enough room so that your neck won't break. With a 4, 5 or 6 point harness, your body has nowhere to go if the roof comes down. With a HANS or similar device, you have even *less* room for your neck and head to move. At least with a rollbar in place (welded or otherwise), the roof is less likely to contact your helmet. A harness bar does absolutely nothing for you in the event of a rollover. Having had a rollbar in my last track car, which I still drove on the street, it's definitely a pain in the butt and introduces other issues besides just convenience. I definitely felt a lot better though when I was hoofing it at 135 into a braking zone, though. |
06-22-2009, 08:00 PM | #21 | |
374
Rep 8,033
You have a good point about what a harness bar would do to you in a car that doesn't have roll-over protection if you end up rolling over. That has been discussed in some detail in another thread. All I can say is that I don't want to be in a car without a full cage next year, which means a dedicated track car. Something with less power would be good as well to keep the top speeds down. Maybe some kind of spec series car...
06-23-2009, 09:50 AM | #22 | |
15
Rep 89
Going to a fully caged car is definitely a smart idea. It's a lot of extra baloney to deal with, cause now you need a truck and a trailer, someplace to store the truck and trailer, but from a safety perspective it's a lot better. |
