Race Car Wheel Question 18x10 front
06-15-2009, 12:13 PM | #1 |
2006 330i, TSM, Black, manual, sport
878
Rep 3,699
Drives: '17 C2, GTI, Z4 3.0si Racecar
I'm working with the Bimmerworks Race Team (a 335 e92) and we're really looking for a cast wheel (not too expensive) that is light weight and an 18x10. We want to run this square of course and either 275 or 285s all around (Toyo DOT slicks). We'll be able to run enough camber to help out with clearance.
I found the Enkei NT03+M in an E46 M3 fitment. It's 18x10 et25. Would this possibly work/fit? Would rolling fenders make them work? I found the wheels for a little over $300 each and they weigh 20.5lbs according to Enkei. Right now we're running the OZ Alleggerita HLT in 18x9 (I'm not sure of the offset), but we're running 15mm spacers up front. I've seen forum members running the Advan RS in 18x9.5 et25 up front with no rubbing issues. We initially thought about running the Advan RS's, but they were just too much money (over $500 each) when we're buying 8 - 12 rims.
2017 Porsche C2 - manual of course
2015 GTI S 2008 BMW Z4 3.0si Coupe - because racecar |
06-15-2009, 12:23 PM | #2 |
Professional Moose Racer
316
Rep 7,509
That will def not for the front.
Visit my blog anytime: http://www.sfpayments.com
BMW Dream Team PNW Chapter, member #1 |HP Autowerks | AR DESIGN | BMW PERFORMANCE | STOP TECH | Volk Racing| AMS | ARKYM |
06-15-2009, 01:02 PM | #3 |
45
Rep 2,575
Drives: '73 2002,'18 X5 35d,'17 328d T
I'm sorry, Did you say that your working with Bimmerworks Race Team? And you're worried about money building a "race car". Those things don't all seem to go together. You'll end up paying twice as much F'ing around trying to be cheap and make something that shouldn't work, work. Do it right the first time or change what you want your results to be to fit the budget.
1988 E28 535is Euro Conversion --- sold 2009 E90 335 6MT --- sold 2003 E39 540iT Msport --- sold |
06-15-2009, 01:39 PM | #4 | |
173
Rep 6,223
2006 E90 Alpine White 330i - Retired
2015 F80 Alpine White M3 |
06-15-2009, 02:26 PM | #5 | |
878
Rep 3,699
We ran the stock wheels with rain tires after the rain delay and were 11 seconds faster than the next car. We're not screwing around (we qualified second also - SCCA 12 hours of Summit Point).
2015 GTI S 2008 BMW Z4 3.0si Coupe - because racecar Last edited by TSM330i; 06-15-2009 at 03:31 PM.. |
06-15-2009, 02:35 PM | #6 |
just another bmw douche bag
195
Rep 3,640
et25 should give you enough clearance on the inside with no (or a small) spacer, so just cut the outside fender as needed to fit. you can then add a plastic flare over the cut fender if you wish, like so:
06-15-2009, 02:55 PM | #7 |
95
Rep 1,476
provided the "race car" isn't leased... hack up the fenders. Speed costs money. And, "good looks" are in the eyes of the beholder.
What does the race team give you in return for you asking internetz questionz? |
06-15-2009, 03:30 PM | #8 | |
878
Rep 3,699
They do all the work on my car at their shop. They take care of me when I come in for something (LSD is on order and they'll be installing it in the next couple weeks).
06-15-2009, 03:37 PM | #9 |
45
Rep 2,575
OK. I don't think you'll be able to fit 275's or 285's up front with stock fenders. no matter what the wheel offset is. and in the rear the 275 or 285 will fit depending on what you have for a wheel well back there.
It looks like you have plenty of suspension. make sure the car is setup correctly, camber, toe etc with whatever square tire setup you can squeeze in. As far as loosing weight...every 10lbs is about 1hp. you usually can get that with the right tire pressure/grip if you are only talking about saving 50 or 60 lbs
06-15-2009, 03:40 PM | #10 |
45
Rep 2,575
there is also a "Tracking, Race, AutoX" section toward the bottom of the tech board. Have a look around there to see what people are successfully runnin
06-15-2009, 05:20 PM | #11 |
878
Rep 3,699
Yup - good suggestion.
06-15-2009, 09:46 PM | #12 |
Perf BMW mag issue 147, 159
414
Rep 6,803
pretty sure the wheel will be hitting the strut
'13 Estoril Blue 335i M-sport
*Don't PM me!* Message me here- http://www.facebook.com/ProjectEstoril |
