What grade engine oil for the 330d?
08-05-2006, 05:19 AM | #1 |
Torque junky
115
Rep 1,688
Drives: Remapped e90 330d
I need to put a drop in before my 3000 mile trip around France & the UK, but the manual just says "your service centre will be able to advise you". Wow, that's a lot of help on a Saturday afternoon.
Anyone know?
www.greenkeepers.fr - spécialiste des tondeuses à gazon hélicoïdales atco qualcast ransomes lawnflite
08-05-2006, 05:27 AM | #2 |
Got Seoul?
116
Rep 2,862
Drives: 2012 535i MSport
Well that can be a problem. I just changed my oil a week or so ago and it went well! Very dirty at 6k. When you say a drop does it tell you that you need to add a quart? If the bar indicator is still visible and you can see where it is and where the MAX level is then you just need to add a little at a time. I think 25% of a quart will be ok until you drive it a day and then check the fluid since the level needs to adjust before adding more. I put in 7 quarts already and it still just says OK. So I'm putting in even less until it says MAX and a date/mileage readout. I hope this helps.
Can you say Alooooha?
[SIGPIC][/SIGPIC] |
08-05-2006, 05:32 AM | #3 |
Torque junky
115
Rep 1,688
Thanks for your quick reply.
Diesel engines have a dipstick to test the level manually (I believe the gas engines have dispensed with this?). According to the manual, the difference between the minimum & maximum on said stick is 1 litre, so I am looking to add 500cc. I am not sure which oil to buy, however...
08-05-2006, 06:04 AM | #4 | |
Got Seoul?
116
Rep 2,862
[SIGPIC][/SIGPIC] |
08-05-2006, 06:06 AM | #5 |
Got Seoul?
116
Rep 2,862
BMW's Long Life-2001 (LL-01) approved oils are BMW 5w30 (really a group III blended synthetic); Mobil 1 0w40 (group IV full synthetic); Castrol 0w30 and Lubro Moly 5w30 (group III blended synthetic).
[SIGPIC][/SIGPIC] |
08-05-2006, 06:10 AM | #6 |
Got Seoul?
116
Rep 2,862
Some good info I found regarding oil levels and how long before it registers.
The sensor "works out" the oil amount, it doesnt just measure it like a dipstick. It requires about 50 seconds of engine on to give you a "initial reading", and will give you a proper "full reading" after 5 minutes of driving. It then updates about every 20min
[SIGPIC][/SIGPIC] |
08-05-2006, 07:00 AM | #7 |
Torque junky
115
Rep 1,688
Great, thanks
