Will 19X10et25 fit on my e90?
05-17-2009, 04:08 PM | #1 |
12
Rep 144
Hello,
Can someone clarify for me if 19X10et25 and 19X8.5et35 will fit on my e90 without too many problems? I'm assuming I will need 10/15 mm spacers in the rear, but once I do that will I rub or have any sort of problems? |
05-17-2009, 04:54 PM | #3 |
Where'd my VTEC go?
481
Rep 6,067
spacers push the wheel out more, so they have the effect of lowering the offset. for example, a 10mm spacer on a +25 offset wheel would yield an effective +15 offset.
05-17-2009, 09:56 PM | #4 |
35
Rep 753
Would an "M" offset of 22mm work though on an E90 with OEM sport suspension? It seems I've seen some here running that combo. I don't want to lower my sport pack car, but want to fill the wheel well as much as possible, don't want to roll the fenders either.
05-17-2009, 10:25 PM | #5 | |
112
Rep 2,433
i think if 9.5" et-22 just fine.better use some skinner tires like toyo t1r or falken 452.
05-18-2009, 08:57 PM | #7 | |
BimmerPost Supporting Vendor
2045
Rep 25,989
-Charles@VMRWheels www.vmrwheels.com
VMR|Wheels | 714.442.7916 |
05-18-2009, 09:42 PM | #8 |
35
Rep 753
I'm going to keep it on the stock sport suspension (E90 330i sedan). I want a wheel/tire combo that helps fill up some of that wheel well though, that is why I opted for the 275's. Plus, 265's on my 9.5" Linea Corse (E39 540 touring) look a bit stretched and I figured a 275 would fit that size rim better.
I'm leaning towards your V713's in the custom bronze powder coat, but not sure how that would look on a sparkling graphite. |
05-19-2009, 02:09 AM | #9 | |
2045
Rep 25,989
Depending on how "flush" you would like your setup, you could always adjust accordingly with about a 5mm spacer. The bronze powder coat finish is definitely a sick color! I love it. Charles@VMRWheels
05-19-2009, 11:26 AM | #10 |
35
Rep 753
My car is an 06 "pre LCI" sedan. Does this make much of a difference on the rear offset? Also, would a 245/35/19 be too much up front, or should I stick with the 235?
05-19-2009, 03:06 PM | #11 |
Rep 129
Subscribing for future reference...I have an e90 08 335 Sedan..and would like the most aggressive look without rolling fenders. Sounds like that 9.5/+33 is it. Thinking V710's. Is the 9.5 with +33 18 or 19 wheel? I was thinking of staying 18...but, maybe go 19. Not sure..doing alot of research now.
05-19-2009, 07:50 PM | #12 | ||
2045
Rep 25,989
Front fitment with 245's should be ok if you are not too low. Fender rolling may be required though. Quote:
05-20-2009, 08:46 AM | #13 |
Rep 129
"Correct, 9.5" +33 with a 275/30/19 rear would be the most aggressive you would want. Anything more would cause some rubbing issues. We do offer the V710's in both 18" and 19" in 9.5 +33."
-Charles@VMRWheels www.vmrwheels.com So what about front fitment? 19x8.5 size..but what offset? I really appreciate your help. My last BMW I did not mod...so, not familiar with BMW type stuff. I had a Cobra I modded the hell out of but, that I feel is a bit different. If something goes wrong with a Cobra..it's alot less expensive to fix...where BMW..not so much. |
