05-16-2009, 02:20 PM | #1 |
374
Rep 8,033
Limerock track report
A few forum members were at Limerock yesterday with their Ms. The weather cooperated and we had a good time. I had some registration issues, so my first session was a bit of a wash (distracted), and there was a lot of traffic, but things improved throughout the day.
This was my first time on the track with the Dinan springs and camber plates. My prior benchmark at Limerock was a PDA event, and things were moving much faster there (less of a skill/equipment spread among the cars on the track). Some qualitative observations instead: 1. The springs indeed feel a bit stiffer. How and if that translates to performance in the presence of some other variables that were different for the day is hard to judge as the stiffness difference is not severe. Putting in significantly stiffer springs would require messing with the dampers anyway, so as we all know, the next step is a quality coilover setup, which I don't plan to do on this car. 2. What is noticable is the effect of the additional negative camber. My fronts are currently at about -1.95 deg. This did make a big difference and reduced the understeer in the stock setup, which was kind of annoying. The car rotates much more freely now (I do have a 265/285 staggered setup) and the turn in is not as much of a struggle. The front tire temps were pretty even across both tires. So, this is a winner mod in my book. 3. The tires got pretty loose for the first time since they were mounted into the 3rd session. This was my 4th track day on them. I think this was the main limiting factor for me during the day (apart from myself!). They did not have the grip they had when they were fresh. I should note that they were not broken-in properly (long story which has something to do with the weather and my inability to drive with 3 sets of tires to the track earlier). It might also have to with me running slightly higher pressures this time. 4. As I mentioned in the other thread, HT10s scored my rotors badly (and faded) at the Glen, so I went with a slightly more aggressive pad, XP12s. Carbotech did not recommend changing compounds/brands without turning the rotors, but I thought the rotors were too worn to be turned, and just wanted to get one more day out of them, so I decided to try the XP12s. This probably does not result in optimum braking performance, but it worked out fine (I did bed the pads in off the track the day before though to make sure they were fine). XP12s kind of machined the rotors faces back to a more even surface and did well. They have high operating temps, but do seem aggressive on the rotors. I think I used about 40%-50% of them in 2 hours, but I haven't pulled them out yet, so can't say for sure.
05-16-2009, 02:36 PM | #2 |
11815
Rep 23,187
very nice. looks like you are getting a ton of track time lucid.
02 Tiag e46 M3|6MT|GC plates|MCS c.o.|GC bars|GC race control arms|GC bushings|BW eng. & tran. mounts|subframe kit|BW race shifter|BW Jaffster|Euro header|BW exhaust|K&N c.a.i.|Epic race tune|Rouge pulleys|Seibon CF hood|CSL bumper|apr gt 250 & splitter|ST-40|XR-2|SS lines|half cage|Recaro profi|Profi 2 harness|BMWpedals|BW studs| |
05-16-2009, 04:00 PM | #3 |
217
Rep 3,593
great write up/video & fantastic driving...I'm still bummed that I couldn't attend...probably going to get my tint corrected next week
'08 E92 M3 6MT | IB | FR | RAC RG63's | VRS Ti Exhaust | Fabspeed HFC & Xpipe '09 X5 35d SG/SB '11 X3 28i AW/CN/FW (wife's car |
05-16-2009, 05:08 PM | #4 |
NASA/PDA Instructor
21
Rep 284
Great job, Lucid. We need to meet up at a local track at a NASA/PDA event...it'd be nice to run with another E9XM. Your lines look good, car control is great...keep it up.
I'm jealous you had r-comps at LRP...great flowing track. For comparo, my vid of last November with the car stock (except mufflers and Pagids/SRF)... Fast times of day were low 1:04s. What do we do differently? Great job, TomK
"Arcadian, I've fought countless times, yet I've never met an adversary who could offer me what we Spartans call "A Beautiful Death." I can only hope, with all the world's warriors gathered against us, there might be one down there who's up to the task."Μολὼν λαβέ!! |
05-16-2009, 05:37 PM | #5 |
374
Rep 8,033
Tom, I watched your videos several times a month ago to familarize myself with the track before my first drive there (had never been there), so they were a great help and I wasn't lost on the track then. Yesterday was my 3rd day at LRP. I will watch them again to see what we might be doing differently, but a few obvious questions:
1. Do you brake before the diving turn or just lift? 2. What is your braking point at the end of the straight? It would be great to have you ride along in a PDA event and give me some advice! Will you be at NJMP Lightning in June?
05-16-2009, 09:40 PM | #8 |
15
Rep 139
Car looked good out there. I am actually in your video, first time going through the downhill, red e46 flashers pulling in the pits. I was just under 1/2 tank and was getting major fuel starve issues through big bend so I just called it a day.
05-16-2009, 09:49 PM | #9 | |
NASA/PDA Instructor
21
Rep 284
TomK
05-17-2009, 10:43 AM | #10 | |
30
Rep 915
I am not familiar with LimeRock, however it looks like it is a 3rd/4th gear track. vz
Previous Track Toy |
05-17-2009, 11:55 AM | #11 |
73
Rep 725
Lucid,
Thanks for the video and I look forward to more information regarding the brake wear. Quick question... how/where did you mount your camera. I have one of the infamous I/O Port camera mounts, but without a roll bar or cage, it doesn't do much good. I'd like to take some in-car video at BeavErun and VIR. Thanks. Dale |
05-17-2009, 12:36 PM | #12 |
374
Rep 8,033
We missed you Monsta. Gotta get things fixed ASAP!
05-17-2009, 12:38 PM | #13 |
374
Rep 8,033
I guess I am OK, but I am not the smoothest driver I think. The first session in the morning was not all that smooth for me, but things got better. Also, things look much calmer/easier in these kinds of videos than they feel in person.
05-17-2009, 12:40 PM | #14 |
374
Rep 8,033
I was wondering about what was going on with your car so early in the session. I am surprised you ran into issues with 1/2 tank?
05-17-2009, 02:57 PM | #15 |
188
Rep 1,153
That was indeed a blast Lucid!!! Thanks for all your advice, insights, tools, .... can' t list it all. I really learned a lot, and I must say: what a car!!! It makes you think you are a good driver too quickly...
Although I will not be tracking as often as you, I look forward to seeing you soon again. PS: so, is it a "ban" for Monsta?!? PS2: I will send you the pics of the stoptech break kit as soon as you PM me your private email.
2019 M2C MT (ED + PCD) | 2008 M3 Coupé MT | 1995 M3 LTW MT | BMW CCA HPDE Instructor
05-17-2009, 04:37 PM | #16 | ||
374
Rep 8,033
I'll PM you about the June event in a few weeks.
05-17-2009, 04:40 PM | #17 | |
374
Rep 8,033
When I pull the pads out later this week, I'll report their thickness.
05-17-2009, 04:42 PM | #18 |
374
Rep 8,033
This works well. Some clubs are not allowing it if you have a passenger though. I mount it on the driver's seat and have it point it away from me.
http://www.cruisecam.com/
05-17-2009, 04:43 PM | #19 | |
374
Rep 8,033
I think Monsta suffered enough, so we'll spare him the ban!
05-17-2009, 06:49 PM | #20 |
15
Rep 139
Yea I was just as shocked. I did some research and there is a $16 part I can get that was a oem baffle that bmw put on the e46 m but not the 330's so I am going to get that ordered and on before NHMS on June 6th. Wont really matter there though as there is no long sweeping rights. You going to that event?
05-17-2009, 07:07 PM | #21 | |
374
Rep 8,033
