E90 owners check your tire pressure !!!
07-25-2005, 06:16 AM | #1 |
Photographer
40
Rep 313
Yes, check your tire pressure. There was a thread about how dealers don't check the tire pressure. I ignored it for the first night and then checked it the next day cuz I thought the ride was a little choppy. All 4 tires' pressure was 35 psi !!! So naturally I reduced them to 29.5 for fronts and 32.5 for rears since it was getting a bit hot. Now, it rides like a dream Perfect road feel and handling
07-25-2005, 06:27 AM | #2 |
102
Rep 614
Yup...I did some driving on some of my favorite mountain roads this weekend. I found raising the front pressure 3-4 psi helps to dial out some of the understeer.
07-25-2005, 06:50 AM | #3 |
Rep 21
I checked mine after reading the thread last week - all about 4psi over the recommended. Can't say I've noticed much difference though
Here's a question:- If I inflate a tyre to say 35psi on a hot summer's day, on a freezing winter's morning will the pressure be much lower (i think it would) and does this mean I should seasonally check and adjust tyre pressure? |
07-25-2005, 07:30 AM | #4 |
General
38
Rep 683
jammy
Yes - its bet to check you tried monthly! Every 10C change in temp is about 1 BAR or 1.5 psi. So a 30C change form winter to summer will be 3 BAR or 4.5 psi - enough to make a signicant difference to the way a car drives. |
07-25-2005, 08:16 AM | #5 |
Rep 91
Mine was 36psi all around. Took the extra pressure off the tires and it drives and handles 10X better.
check out http://www.corrinnemay.com
2006 325i Blk Sapphire Metallic, Beige Lthr, ZPP, nav, sat, xenon, fold-down seats and premium hi-fi. |
07-25-2005, 08:51 AM | #6 |
40
Rep 215
I completely agree!!
I had to get my front left tire changed because I got a flat. The dealership left the tire at 44psi!!!!!! it was at 47 when hot. the others were at 34psi when cool. so I had to lower the pressure but yes, check your tire pressure!!!!!!! I left all the tires at 34psi. is that too hight? |
07-25-2005, 02:26 PM | #8 | |
Rep 82
07-25-2005, 02:55 PM | #9 |
3566
Rep 10,346
The dealer may check the tire pressure in their workshop which is usually much cooler (A/C running all the time) than the outside, so that might be a reason for higher than normal pressure upon delivery.
10 degree change in temp = approx 1 lb psi. |
07-25-2005, 08:08 PM | #10 | |
44
Rep 722
07-25-2005, 08:19 PM | #11 | |
121
Rep 2,099
I got a slow leak from running over a nail...patched with no problems (yet). But it sure was one helluva wake up call! |
07-26-2005, 05:37 AM | #12 | |
Photographer
40
Rep 313
07-28-2005, 08:49 AM | #13 | |
Rep 74
07-28-2005, 09:02 AM | #14 | |
Photographer
40
Rep 313
Normal driving conditions and light load for everyday driving is much lower. It is on owner's manual. Yes, I read it. |
08-02-2005, 03:38 PM | #15 |
Rep 45
My car was delivered with tire pressures all over the place, not inspiring confidence in my friendly dealer.
Yes, we've got to check the pressure manually periodically because of the way the car determines a problem with tire pressure....unlike some other cars (and other, more expensive BMW's) pressure problems with the tires are not picked up via a pressure sensor but rather they're inferred from a detected difference in rotational speed of one of the tires. So as the manual points out, a slow degradation of tire pressure on ALL four tires will not be detected (to be expected with all tires over time). As per the manual. |
08-03-2005, 07:58 AM | #16 |
Rep 46
My car was delivered with 38psi all around. Changed to 29/32 pursuant to the manual.
2006 E90 325i
TiAg; Black Leather; 6-Speed Manual; Sport Package; Heated Seats; Sat. Prep; modified CDV (Zeckhausen); Rogue SSK |
06-24-2006, 06:46 PM | #17 | |
65
Rep 920
Drives: 06 E90 330i 6MT, 01 E46 330i
Mine is the same all I have is this one sticker but my production date was 3/05
06-24-2006, 11:35 PM | #19 | |
27
Rep 959
Sticker for me says 32/36, or 35/41 for high speed. I'm currently running 35/38 and like the feel. --gos
330xi SG/Terra/Burl -- ZPP, ZSP, ZCW, CA, Sirius, PDC |
06-25-2006, 05:10 PM | #20 | |
25
Rep 513
2006 330xi
[TiAg] [Black Leather] [Aluminum] [STEP] [ZPP] [ZSP] [ZCW] [CA] [35% tint] [Blacklines] [OEM Strut Bar] [OEM Spoiler] |
06-25-2006, 06:47 PM | #21 |
364
Rep 5,842
Drives: 2006 325xi
Now what do you do if you have differet wheels and tires on the car. For instace i have a set of 19 Goodyear Eagle F1's on my 325xi - What pressure should i use??
06-28-2006, 07:58 PM | #22 |
364
Rep 5,842
Drives: 2006 325xi
bump above Q
