BMW M3 Forum (E90 E92)
Go Back   M3Post - BMW M3 Forum > E90/E92 M3 Technical Topics > Track / Autocross / Dragstrip / Driving Techniques
EXXEL Distributions
      05-03-2009, 11:28 AM   #1
Roaders
Roaders's Avatar
Drives: E92 M3 DCT
Wheel Torque settings
Hi
I've got the OEM 19s on my car and will be getting a set of OEM 18s for use as track tyres. I assume that when I swap these over I should use a torque wrench to tighten them up.
Is the correct torque listed anywhere in the manual? I assume it'll be the same for both sets of wheels.
Thanks
      05-03-2009, 11:33 AM   #2
lucid
lucid's Avatar
374
Drives: E30 M3; Expedition
88 ft lbs
      05-03-2009, 11:43 AM   #3
1MOREMOD
1MOREMOD's Avatar
11817
Drives: Race car->
what he said.
02 Tiag e46 M3|6MT|GC plates|MCS c.o.|GC bars|GC race control arms|GC bushings|BW eng. & tran. mounts|subframe kit|BW race shifter|BW Jaffster|Euro header|BW exhaust|K&N c.a.i.|Epic race tune|Rouge pulleys|Seibon CF hood|CSL bumper|apr gt 250 & splitter|ST-40|XR-2|SS lines|half cage|Recaro profi|Profi 2 harness|BMWpedals|BW studs|
      05-04-2009, 04:07 AM   #4
Roaders
Roaders's Avatar
Drives: E92 M3 DCT
Thanks guys, is that out of the manual? I couldn't see it.
      05-04-2009, 10:02 AM   #5
1MOREMOD
1MOREMOD's Avatar
11817
Drives: Race car->
didnt look for it in the manual. this is just what i have been told my numerous people when i asked. Stricly BMW, les schwab, BMW service. its 88.
      05-04-2009, 10:12 AM   #6
gambitx28
shop smart, shop s-mart
gambitx28's Avatar
Drives: 2015 640i GC
yeah, 88 is what my old E46 manual recommended, so I too have been using that setting for the E90 M3 as a 'good enough' guess.
2015 X5 xdrive35i
2008 E90 M3
2002 325Ci Convertible
      05-04-2009, 03:51 PM   #7
lucid
lucid's Avatar
374
BMW doesn't want us to touch our cars anymore, so no more torque specs or dip stick for us!
Chewo3.00
      05-05-2009, 11:32 AM   #8
tszene
137
Drives: M4
      06-01-2009, 01:57 AM   #9
Thinker23
Thinker23's Avatar
Drives: '09 E92 M3 - AW, 6MT
130N-m indicated on the wrench that came with the BMW jack set.
130N-m= 95 ft-lb
      06-01-2009, 03:02 AM   #10
bigjae1976
bigjae1976's Avatar
1570
Drives: 11 E90 M3 Individual
2004 BMW M3  [4.50]
2011 BMW E90 M3  [5.25]
2013 BMW 328i  [5.00]
IIRC there was a TSB that changed the wheel torque spec from 88 ft/lb to 92 ft/lb for E46s. I know I changed from using 88 to 92 for a reason.
2018 F30 320iX Melbourne Red
2011 E90 M3 Monte Carlo Blue
2004 E46 M3 Imola Red
2000 E36/7 Z3 Steel Blue
      06-08-2009, 11:15 AM   #11
Roaders
Roaders's Avatar
Drives: E92 M3 DCT
Thanks for your replies guys.
I just phoned up BMW service and he said that the torque setting is 120 ft lbs for the E92 M3.
Is this different as you guys are talking about E46?
      06-08-2009, 11:23 AM   #12
lucid
lucid's Avatar
374
This is good info. Thanks. But it contradicts the info posted above by Thinker23. I wonder if his jack set was M3 specific. I've been going with the E46 spec after asking around BMW CCA folks as I couldn't find any specs in the manual for the E92 M3. I now feel the need to call my service guy since we have too many different numbers floating around. Does anyone have a "published" spec on this?
      06-08-2009, 12:03 PM   #13
Dascamel
Dascamel's Avatar
48
Drives: 2008 e92 M3, 2010 e91 328i
120 seems extremely high? Anyone verify this? 50% increase? I would be shocked if it differs greatly from 88, thats what I had torqued for 3 consecutive track days, none of them budged.
2008 E92 M3 Jerez Black,DCT,Fox Red ext,Prem,Tech,19", ipod/usb, CF roof and trim
2010 E91 328i Space Gray,Black int, M sport, most options
2007 Montego Blue 335i (retired)
      06-10-2009, 01:56 AM   #14
Roaders
Roaders's Avatar
Drives: E92 M3 DCT
I'd rather have it too tight than too loose!
      06-10-2009, 03:00 AM   #15
bigjae1976
bigjae1976's Avatar
1570
2004 BMW M3  [4.50]
Correction, the change was from 74 lb/ft to 88 lb/ft +/- 7 lb/ft.
120lb/ft? That seems pretty high. I guess a tech or service advisor would have the right answer for sure.
      06-10-2009, 03:34 AM   #16
Roaders
Roaders's Avatar
Drives: E92 M3 DCT
Can someone else phone up their service department and ask the same question? If we get the same answer I think we can believe it.
What's the downside for having it too tight? Damaging the wheels?
      06-10-2009, 09:15 AM   #17
J08M3
J08M3's Avatar
285
Drives: 2011 M3 COUPE
warped rotors I believe??
Got mine at 90 ft. lbs and my wheels haven't fallen off yet think I'll leave it.
      06-10-2009, 09:24 AM   #18
FStop7
I like cars
FStop7's Avatar
Vatican City State
329
Drives: M6
120ft-lb? sounds way high. 90ft-lb has been the norm forever.
      06-10-2009, 12:36 PM   #19
lucid
lucid's Avatar
374
You don't want to overtorque it as it might fail. Here is an example of a failed bolt from the Rogue Engineering site:
http://www.rogueengineering.com/Merc...t_Code=WSPACER
They also state that the BMW spec for M12 bolts is 88 ft lbs. I don't have access to my car, so I can't check to see what kind of bolts are on it. Someone should check this, and call their SA. RE says spec is higher for M14 bolts.
      06-10-2009, 01:20 PM   #20
r53s65e90
8300
r53s65e90's Avatar
19
Drives: r53 s65e90
Weird. 120 lbft is too high IMO. Also 120 nm is 90 lbft which can explain the SA misfire.
Shortly after delivery my lug nuts where <90lbft so no way 120 is the way to go. I keep them at 90 lbft.
I don't trust random SAs but I will ask the good independent shop I use for my track inspections and misc work.
      06-10-2009, 01:21 PM   #21
Gearhead999s
Gearhead999s's Avatar
814
Drives: RR Velar R=Dynamic M2C R1200GS
Torque wrench thats for girls I prefer this method
      06-10-2009, 03:21 PM   #22
von_zoom
von_zoom's Avatar
30
Drives: 2010 Z06
I agree with 120 being too tight. 88 to 90 sounds correct. Mine were in the 90 lbs range on delivery however I have no confirmation this is the correct setting. Over tight can cause failure. I have seen it happen at the track. Lugs will expand as they heat up.
vz
Previous Track Toy
m3post
